Spark plugs question.
Old Feb 16, 2007 | 07:17 PM
NOMORECHEVY's Avatar
NOMORECHEVY
Default Spark plugs question.
[sm=feedback.gif]I'm ready to replace the spark plugs in my 1998 Dodge Ram 1500 V8 (5.2) The Emissions Label under the hood ask for RC12LC4.My question is:.....arethere any other brands, type or equivalentspark plugs better than the standard ones? Which one will you recommend and why?....Thanks guys![sm=deal.gif]
Old Feb 16, 2007 | 07:48 PM
padodgeram's Avatar
padodgeram
Default RE: Spark plugs question.
I use the run of the mil autolite 5224 dont need nothing special... plus autolite treated me well..nothing wrong using champs either or ngk ...
Old Feb 16, 2007 | 08:02 PM
Silver_Dodge's Avatar
Silver_Dodge
Those Champion plugs that come stock are a good copper plug and will always be good in your truck if it is stock or near stock. I currently run Autolite 3923. They are one temp range colder then the stock plug, and help to prevent pinging if you have mods that might advance timing.
Old Feb 16, 2007 | 09:57 PM
1996Ram318's Avatar
1996Ram318
I have Bosch Platinum +4s in mine. They run great and improved my gas milage.
Old Feb 16, 2007 | 10:03 PM
hometheaterman's Avatar
hometheaterman
I've always heard Bosch's reffered to as crap and heard of lots of people having problems with them. I've heard lots of good things about the Autolite 3923's but I ran them and had what felt to be a mild missfire with them. I couldn't figure out what it was so finally decided to try a set of Champions again and it went away immediately. This has scarred me away from Autolites but I've heard of quite a few people running them no problem.
Old Feb 16, 2007 | 10:21 PM
TMS Bill's Avatar
TMS Bill
ORIGINAL: 1996Ram318
The consensus here is that Platinum +4s are the worst plug you can install in the Magnum engine.
Champion Truck Plugs are what you want.
Old Feb 16, 2007 | 11:31 PM
lancelanz's Avatar
lancelanz
ORIGINAL: hometheaterman
i had the same exact problem when i changed my plugs a few months ago i but in autolite platinums in and it ran like crap so i swapped them for stock champions and now it is running like a champ(no pun intended lol)
Old Feb 17, 2007 | 12:37 AM
mattyge's Avatar
mattyge
i've had good luck with ngk, champ, and autolites
Old Feb 17, 2007 | 12:58 AM
hometheaterman
I've had good luck with NGK's in my motorcycles and Honda's but never tried them in my Dodge.
Old Feb 17, 2007 | 02:17 AM
TPSDODGE's Avatar
TPSDODGE
the best plug hands down for a stock truck is rc12yc champions that came in it if you have a pinging prob due to advanced timing get the autolights or even the rc9yc champs but if you ping check you plenum gasket (search)
