misfires and constantly needs new roders
Old Feb 19, 2007 | 11:28 PM
Jacks2001ram2500's Avatar
Jacks2001ram2500
Default misfires and constantly needs new roders
the roders have broken twice on my dodge 2500 5.9 magnum. what would cause them to break?
Old Feb 19, 2007 | 11:57 PM
Cereal Killer's Avatar
Cereal Killer
Default RE: misfires and constantly needs new roders
Not changing the brake pads in time
Old Feb 20, 2007 | 12:07 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
Sounds like you are using bad quality pads.
Old Feb 20, 2007 | 12:22 AM
Jacks2001ram2500
roders for the engine.. im sorry
Old Feb 20, 2007 | 12:33 AM
red98ram's Avatar
red98ram
i think its spelt rotor
Old Feb 20, 2007 | 12:36 AM
dhvaughan's Avatar
dhvaughan
distributor cap rotor...
somebody recently had a thread where the rotor cut a groove inside the cap. he found a rock in the distributor that was causing it to fit improperly. due to the impossible location behind the #$#% motor, he couldn't see it.
i'm guessing....
misfit cap or rotor, not on straight
cracked, broken, cap
bent rotor shaft
too hot coil,
water or other conductive getting inside cap
might try removing throttle body to get a better look. a few bolts and some cables, not too hard to remove.
Old Aug 8, 2007 | 08:31 PM
chelle26's Avatar
chelle26
sounds that it is your brake pads! brake pads bear the brunt of brake operations....when calipers tightens, brake pads are pushed against the disc and retard the motion of the car..A direct contact with rotor, dodge brake pads serves as maintenance item that needed to be replaced regularly...
Old Aug 8, 2007 | 11:18 PM
atcsat64's Avatar
atcsat64
I'm confused, we talking brake rotors or ignition rotors?
Old Aug 8, 2007 | 11:28 PM
padodgeram's Avatar
padodgeram
[sm=confused06.gif]
Old Aug 9, 2007 | 12:00 AM
atcsat64's Avatar
atcsat64
If we're talking ignition, bent shaft could cause the rotor to break I think, and misfires. Has the engine ever been out of the truck? I've seendistributors broken and bent in engine swaps by hitting the firewall (OK, I was young then) but it's awful hard to bend a distibutor shaft while in the truck and I think it's something else. Did you change the cap and rotor last time it broke?
