steering loose
Old Mar 4, 2007 | 04:03 PM
iowaman0322's Avatar
iowaman0322
Default steering loose
I have a 98 ram 1500 4x4. I've replaced the steering gear box, drag link, tie rods, and steering stablilzer. The steeringisbetter then beforebut there stillmaybe a 2-3 inch play before the wheels turn, it's same either way i turn the wheel. Does anyone know what would be wrong. the only thing i canthink of is thesteering shaft. would the ball joints cause anything like this. Or would adjusting the gear box fix the problem.
Old Mar 4, 2007 | 04:50 PM
bamory's Avatar
bamory
Default RE: steering loose
Control arm bushings, replace both upper/lower both sides and use polyurethane. This will make a huge difference providing everything else is tight.
Old Mar 4, 2007 | 10:52 PM
iowaman0322
what are the control arm bushings. that doesn't have anything to do with the sway bar does it.. do you know of a diagramn
