Question about PCM relearning and programmers
Old Mar 7, 2007 | 11:27 AM
TPSDODGE's Avatar
TPSDODGE
Default RE: Question about PCM relearning
you should go to the dealer and have them diag it for you they charge anywhere from 60-100 bucks but its worth it. This way you can stop guessing and trowing away money. as for injector cleaner you should do like bill said or get somebody to do the through the rail stuff for you it really works best. You could always just take the fuel rail off and clean it out by hand, go buy a sonic jewlry(sp) cleaner use some solvent and clean the injectors yourself. But then that prob wont fix your prob. Do you have any cel coming on? theres a code for internal pcm failure.
Old Mar 7, 2007 | 11:40 AM
BradBeyer's Avatar
BradBeyer
there is no CEL coming on and I am going to pull off the fuel rail today and clean it....is there anything I need to know about pulling it off...do I need anything (special tools or gaskets) besides the jewelry cleaner?
Brad
Old Mar 7, 2007 | 03:48 PM
TPSDODGE's Avatar
TPSDODGE
Yup you will need a fuel line removal tool and prob some new orings do you know how to use the jewlry cleaner? just do a search on google and youll find some good instructions hope that helps
