Death Wobble
Old Mar 15, 2007 | 12:44 AM
97Ram2500's Avatar
97Ram2500
Default Death Wobble
Well it seemed that I just had my first experience with the death wobble. I was towing my motorcycle down the freeway and I hit a bump and the truck started shaking violently. It stopped when I got down to about 35 mph. I took a picture of a broken piece under there I think it is the link for the stabilizer bar, could you verify this for me and would this cause the problem? It is a 4x4.
[IMG]local://upfiles/47658/3B5A0C284DBD4122BC27C72CF51E8EAF.jpg[/IMG]
Old Mar 15, 2007 | 01:13 AM
TMS Bill's Avatar
TMS Bill
Default RE: Death Wobble
Yeah ... that's a sway bar link. Shouldn't cause DW though. I think RockAuto has some pretty cheap. If you trust eBay stuff ... I've seen them there, too. Take off both sides (and the bar) untill you get a chance to fix it.
Old Mar 15, 2007 | 01:26 AM
97Ram2500's Avatar
97Ram2500
Hmm. Ok I'll do that. I know I have agood amountof play in the steering and after that happened my steering wheel isn't straight on anymore.
Old Mar 15, 2007 | 01:38 AM
TMS Bill's Avatar
TMS Bill
Ever done anything with your track bar? That sway bar may have been the only thing keeping your axle centered.
Old Mar 15, 2007 | 02:11 AM
97Ram2500's Avatar
97Ram2500
Not trying to sound stupid, but which bar is the track bar?
Old Mar 15, 2007 | 03:59 AM
ram51's Avatar
ram51
It's the bar thatbolt's on topof the right side of the axle and stretch'sto the left side above the axle just had mine replace Broke it hitting a big pot hole the track bar cost me $300 alone from the dealer then I find out advance auto had for $144..
Old Mar 15, 2007 | 04:11 AM
dirty_d's Avatar
dirty_d
yeah and you can get a bullet proof thuren for about 300.00 and it corrects your axle for lifts up to 7 inches
Old Mar 16, 2007 | 12:42 AM
TMS Bill's Avatar
TMS Bill
This is the one I put in: http://www.dtprofab.com/dodge.htm
97RAM2500: It's the bar that's supposed to keep the front axle centered. It reaches from the right side of the front axle up to the left frame rail where it uses a weak-assed ball mount. One of the weak links on the 2nd Gen 4x4 front suspension. Once it wears out ... the axle will drift laterally forcing you to steer to correct ... Death Wobble. Never replace it with a stock unit. There are a number of aftermarket units that are 10X better.
It's probably why you broke the sway-bar link.
Old Mar 16, 2007 | 01:19 AM
97Ram2500's Avatar
97Ram2500
I don't think I will be keeping this truck too much longer, so is there a cheaper on that I can get that will at least serve it's purpose for a little while?
Old Mar 16, 2007 | 02:03 AM
TMS Bill's Avatar
TMS Bill
Look here: http://www.lukeslink.com/
You can rebuild your stock bar ... web site says $66.
