Top speeds on gears??
Old Mar 16, 2007 | 01:08 AM
mikerados21's Avatar
mikerados21
Default Top speeds on gears??
Okay welli was talking to my friend tonight and he said he was going to put 3.73's in his truck and i told him i was goin to put 4.10's in mine. well he told me i wouildnt be able to go over 100mph??? well can anyone tell me a general idea of top speeds wit the
3.90's
4.10's
and 4.56's
Thnx guys!!!
Old Mar 16, 2007 | 01:40 AM
ramchrgr88's Avatar
ramchrgr88
Default RE: Top speeds on gears??
gears dont matter if the tire size is bigger. then the gears will just be the same total ratio as stock if you upgraded to a larger tire. even if you went up in gears to a 4.56 without changing tires too much, you will only be running about 5-600 RPM more than with the stock gears.
Besides, why on earth would you take a 5000 lbs. truck over 100. not only is it illegal, but just plain dumb. stopping in a hurry is out of the question, and if you lose any control, you wont spin out like a sports car...you become a tumbleweed.
Old Mar 16, 2007 | 02:43 AM
mikerados21
ORIGINAL: ramchrgr88
Well I do run my truck at a local drag strip against other stock ones so im tryin to make it were i can race it on the drag strip alot cause i got another truck i drive for daily. my ram had uprgraded cross drilled rotors (Baer) and bettercalipers and brake pads. its about to get lowered a little bit. then tubbed out. its already got a roll cage and 5 pt. harness cause it manditory for the track. so im just curious if it would do over 100 wit 4.10's
Old Mar 16, 2007 | 07:02 PM
ramchrgr88's Avatar
ramchrgr88
no gears will get over to 100mph in the quater unless you get some serious engine work done. check out rm-indy's page. he has a 5.9L motor and didnt do it until he was supercharged. dont get your hopes of 100 mph in your truck.
Old Mar 16, 2007 | 07:26 PM
mikerados21
well notr specifically in the quarter lets just say if i were to have it at WOT will it go over 100? Just top speed...
Old Mar 18, 2007 | 04:22 PM
DeadLifter's Avatar
DeadLifter
What are your RPM's at 50 just double that. Mine are around 1,800 at 55 with 4.10's so at a hundred I'd be well under 4,000 RPM's, but I doubt my truck will ever see 100 with me drivin. I'll save that for bikes and cars.
Old Mar 18, 2007 | 06:43 PM
mopowar's Avatar
mopowar
Check this out:
http://www.f-body.org/gears/
Just plug in the variables and it will tell you what your speed will be at any given rpm
Old Mar 18, 2007 | 07:41 PM
junkman306's Avatar
junkman306
ORIGINAL: mopowar
Check this out:
Too bad I don't know my transmission ratio's for each gear.
Old Mar 18, 2007 | 08:19 PM
mopowar's Avatar
mopowar
Which tranny do you have?
46re=
Gear Ratios
1st
2.45
2nd
1.45
3rd
1.00
4th
0.69
Old Mar 18, 2007 | 09:05 PM
junkman306's Avatar
junkman306
Ithink mine is the 44re.
