Articulation
Old Mar 16, 2007 | 11:12 AM
RetroCow's Avatar
RetroCow
Default Articulation
I have a 2001 2500 QC CTD 4x4 and I would like to get a little more articulation. The only thing I've been told is to get different springs, but being a diesel it's kinda heavy and softer springs doesn't seem like the way to go. Is there a way to remove the sway bars or something similar to get more articulation?
Old Mar 16, 2007 | 01:12 PM
Silver_Dodge's Avatar
Silver_Dodge
Default RE: Articulation
Yup, the sway bar removes very easily. Will take some getting used to driving it like that, but I know lots of guys who don't even run one anymore.
Old Mar 16, 2007 | 01:24 PM
Socha_62's Avatar
Socha_62
What silver said
Old Mar 16, 2007 | 04:28 PM
landarch96's Avatar
landarch96
I have a similar set up to you except for your 6" lift. I took it off but didn't like it for normal driving. So, I fabbed my own quick disconnect sway bar. A little cutting, welding and a $2 pin makes for a pretty good solution. I just pull the pin when I'm heading off road. The only downside is it's sometimes a pain to get holes lined up to put the pin back end. Truck has to be sitting on a hard level surface to stand a chance of getting them to line up.
Check out www.jksmfg.com quick disconnect sway bar. These are for Jeeps but should give you the idea. Mine looks pretty similar, just not painted fancy like theirs.
Old Mar 18, 2007 | 09:10 AM
RetroCow's Avatar
RetroCow
And which one is the sway bar...never really done anything with suspension before.
Also, is there one on the front and rear?
Thanks guys
Old Mar 31, 2007 | 04:02 PM
94ram15004x4's Avatar
94ram15004x4
sway bar will give you more flex. thats the way to go. i took mine off and dont ever plan on putting it back on. there isnt a rear sway bar on my truck but i belive 98 and new has rear sway bars. .. not positive though. the sway bar will be a solid bar that hooks to both sides of the axle ( drivers and passengers sides) with a link in between the bar and the axle.
Old Apr 2, 2007 | 09:42 PM
TMS Bill's Avatar
TMS Bill
Pretty sure 3/4 tons have 2. 1/2 tons only have the front ... unless you add one to the rear like I'm gonna.
Old Dec 8, 2007 | 01:12 PM
phre0n's Avatar
phre0n
there's not a company that makes quick disco's for soild axle 94-01 1500-3500 trucks? i really want a set.. wondering if a set for a jeep w/3in lift would work?
Old Dec 8, 2007 | 01:18 PM
ICEMAN_CH's Avatar
ICEMAN_CH
ORIGINAL: landarch96
Mind putting some pictures up?? Also is the links hollow already so that all you have to do is get another chunk to fit inside?
