lift kits
Old Mar 18, 2007 | 08:24 PM
smokin01dodge's Avatar
smokin01dodge
Default lift kits
I have a 2001 dodge ram, already lifted 3" and 3" body lift and i wanna get a bigger suspension lift kit and was wondering what the biggest one was, and what i have to change.
Someone also told me to change the back leafspring to spring? so i dont have to put like 6" block under the leafspring, is that true
Old Mar 19, 2007 | 12:44 AM
mopar man 6978's Avatar
mopar man 6978
Default RE: lift kits
well the bigger you go the more you will have to modify your truck if you want to go much bigger than a 5 inch suspension youll have to extend steering, brakes, and fuel lines, and you'll have to get a transfer case drop kit and brakets to drop your pitman arm because alot of places wont allign your weels with out it
[align=left] [/align]
Old Mar 19, 2007 | 01:02 AM
spaz_22's Avatar
spaz_22
let me know if your going to sell your 3 inch lift.....
Old Mar 19, 2007 | 01:27 AM
smokin01dodge
alright, i was thinking on duing the skyjacker 7" lift and keep my 3" body lift.
Old Mar 19, 2007 | 01:34 AM
Checkmate's Avatar
Checkmate
I have 8" in my suspension and the 5" drop pitman works fine as does the stock located transfer case.
Old Mar 19, 2007 | 03:16 AM
Ram4x4sport99's Avatar
Ram4x4sport99
2nd in line for the 3" susp. lift
Old Mar 19, 2007 | 03:44 AM
hometheaterman's Avatar
hometheaterman
I'd go 7" Skyjacker with the 3" BL if you want big. If you want big but still not huge I'd look into a 5" or 5.5" kit with the 3" body lift. Thats the setup I'd really like to be running.
Old Mar 19, 2007 | 01:48 PM
smokin01dodge
im prob going with the 7" with 3" body, what will i have to modify as steering and stuff like that?
Old Mar 19, 2007 | 09:21 PM
mopar man 6978
they should send you all the necisary extensions, but extending steering is a bitch
Old Mar 19, 2007 | 10:34 PM
20dodgeram01's Avatar
20dodgeram01
whiplash makes a 10 inch lift for the 94-01 ram.. just the front box though... 14 inch lifts for 02-05 rams
