ram radio problem
hey all got a '98 Dodge ram 1500, just this week the radio and all interior lights on the ceiling of the truck went out. The lights are supposed to come on when the door opens and/or if the dome light **** is turned, but nothing. Completely dead. Radio too. Checked all fuses both inside the truck and under the hood. Help please! Thanks, Greg
Yea take them out and look at them close sometimes you can barely see the cracks, ive installed like 4 aftermarket head units in 2 different reams its always a fuse inside or the big fuse under the hood
Well I checked the fuses again and I found one inside the panel in the cab of the truck with a black security-type cover over it that I couldn't previously get off. I was able to get it off and sure enough it was that fuse. But every time I replace it it blows instantly. The diagram says its the I.O.D. fuse, any ideas? Maybe something else needs to be replaced at the same time this replaced? It doesn't seem like something the average do-it-yourselfer should be touching, with that cover over it and all. Thanks
Sounds like a short circuit. Which could be a real PITA! The seatbelt solenoids are off of that fuse and I had trouble with them staying picked up before, but they never blew a fuse. Maybe have a look at them. Unplug the connector from the rollover sensor under the middle seat and see if it still blows. If it does, try disconnecting things one at a time. You will probably go through alot of fuses.
Alright well thanks for all the help. I actually disconnected the bulb from the main interior light and just left the two small lights on the front of the ceiling and the radio connected and the fuse hasn't blown...........must be something with that big light in thecenter of the truck.....oh well for now its fine.
ORIGINAL: Magnumpwr16
Trending Topics
