Trailer brake wiring??
Old Mar 21, 2007 | 03:03 AM
priest1981's Avatar
priest1981
Default Trailer brake wiring??
I just got a 98 1500 sport quad-cab 4x4 with a 5.2 and a manual transmission. I was wondering if it is pre-wired for a trailer brake controller and where the wiring is. I know some trucks have wiring under the dash and the bed, I'm just not sure on my new Ram.
Thank you,
Will
Old Mar 21, 2007 | 11:45 AM
hilliad's Avatar
hilliad
Default RE: Trailer brake wiring??
If your truck is prewired it will have a connector down under the steering wheel. You can just plug the brake box right into it. You will also have to take your light connector apart and reverse the two wires that are not soldered. otherwise your trailer brakes will be locked at all times.
Old Mar 21, 2007 | 04:37 PM
priest1981's Avatar
priest1981
What does the connector look like? Do you have a picture?
Thank you,
Will
Old Mar 21, 2007 | 07:29 PM
landarch96's Avatar
landarch96
No picture, but....Its a plastic connector (I think female) with a clip type fastener. The face of the connector is rectangular and is about 1" x 3/4". If you haven't used it before, it will probably still be stuffed up under the dash. Just reach up and feel around for a loose connector. The pigtails will be long enough to pull it down a few inches below the dash panel.
Old Mar 21, 2007 | 11:34 PM
kayakman's Avatar
kayakman
Hi Hilliad, what two wires are you talking about. I have a 98 and all i had to do is plug my brake control in. Have a Terry 22' 5th wheel trailer duel axle.
Old Mar 22, 2007 | 11:28 AM
hilliad's Avatar
hilliad
It is the part that plugs in your hitch that connects your trailer wires. Open it up and reverse the two wires that are not soldered together.
http://www.dodgeram.org/tech/mods/el...ailer_wire.htm
