Sluggish starting
Old Mar 21, 2007 | 10:11 PM
mcss8541's Avatar
mcss8541
Default Sluggish starting
My 98 Ram 1500 has suddenly started to have starting issues. Normally when I start it up she fires right up; however the last 2 days it takes a long cranking cycle then she starts. When she starts she fires right up it's just now it's taking longer. I've been told that it could be a bleed off from the fuel pressure regulator, fuel pump might be going bad, spark plugs, etc. I have the 5.9L V-8 fuel injection and it's a 4 wheel drive truck. Thanks!
Old Mar 23, 2007 | 05:25 AM
Cereal Killer's Avatar
Cereal Killer
Default RE: Sluggish starting
Mine does the same thing.
Old Mar 23, 2007 | 01:26 PM
Silver_Dodge's Avatar
Silver_Dodge
Giver her a tune-up, and see if that helps. Plugs, cap, rotor, etc... Then clean the TB, escpecially the IAC.
Old Mar 23, 2007 | 03:02 PM
tdmopar59's Avatar
tdmopar59
also the way i am reading this im not sure if i have it right but possibly your battery is starting to die out or you might need to clean your connections....
Old Mar 23, 2007 | 03:13 PM
Cereal Killer
That's a possibility, there's all kinds of sick **** on my batttery terminals I've been meaning to clean off.
Old Mar 23, 2007 | 03:14 PM
Cereal Killer
When I d/c the battery should I disconnect the Negative or positive first. I forget which way I did it last time and I got ****ing nailed reconnecting it.
Old Mar 23, 2007 | 03:16 PM
tdmopar59's Avatar
tdmopar59
to be safe remove the positive first make sure you dont let your wrench hit a ground..... and one you put it on connect the ground first
Old Mar 23, 2007 | 04:38 PM
mcss8541's Avatar
mcss8541
How did you get the pic of your truck uploaded? Everytime I try it tells me it's too large and one of them I took with my camera phone.
Old Mar 23, 2007 | 05:03 PM
Cereal Killer
I had it uploaded on imageshack.com and put the linking code in my signature. [IMG]*put the link in here* [/IMG]
Old Mar 23, 2007 | 05:04 PM
Cereal Killer
ORIGINAL: tdmopar59
Thanks, I feel like a dumbass when I have to ask questions like that but it's somewhat less painful than electrocution
