Removing Decals?
Old Mar 22, 2007 | 03:14 AM
20dodgeram01's Avatar
20dodgeram01
Default RE: Removing Decals?
just take a razor blade to it.. f--- it. i have a 01 and the only problem i had with it was that when dust got on the truck.. it didnt stick to where the stickers where.. why? i dont know.. but after acouple coats of wax its fine now.. also my truck is black so you see everything.. you wont notice it with a white truck
Old Mar 22, 2007 | 03:41 AM
nolazach's Avatar
nolazach
Heat gun or hairdryer, works quick, just don't hold it in one spot too long. Harbor freight as guns for $9, works for removing stickers, and all kinds of stuff, worth while to have.
Old Mar 23, 2007 | 02:29 PM
01dodgeram's Avatar
01dodgeram
I removed all of the decals on my truck and the only place where there is a color difference is by the front fenders on my doors where I took the side molding off at. I have not tried buffing it or any thing yet though.
[/align]
Old Mar 23, 2007 | 03:40 PM
dishdude2k's Avatar
dishdude2k
when i took the decals off of my old truck.. i had this nasty looking pinstriping design all down both sides.. i used a razor blade to get it off.. get it started u can just pull most of it off.. be careful not to press too hard tho and scratch the truck.. then i used 3M Adhesive remover.. put it on a shop towel.. and just wipe the adhesive off.. dont let it sit on the paint tho.. it can damage it if u let it sit.. but it worked great.. and shined it up.. when i was done.. you couldnt even tell there was anything there
Old Mar 23, 2007 | 04:20 PM
97Ram2500's Avatar
97Ram2500
I don't trust myself using a metal razorblade on my truck. They make plastic razor blades that work good I bought a kit from autzone with some sticker removing solution and a plastic razorblade. Worked good for me.
Old Mar 23, 2007 | 04:35 PM
mcss8541's Avatar
mcss8541
That's what I was recommending to you earlier. I'm glad everything worked out.
