transmission
Old Jan 23, 2011 | 11:29 AM
rogershawn's Avatar
rogershawn
Default transmission
I have a 98 ram 1500 5.9 4x4 with a bad transmission. Will a 99 durango 5.9 4x4 transmission fit in it?
Old Jan 23, 2011 | 11:34 AM
If it has a 46RE in it, it should physically bolt up, might be some wiring differences though. Not sure on that. Dodge did some strange things with wiring over the years...
Old Jan 23, 2011 | 11:39 AM
zman17's Avatar
zman17
Retired Moderator - RIP
+1... I wouldn't take the chance. Find one out of a Ram 98-99 only.
Old Jan 23, 2011 | 01:12 PM
bjr1a's Avatar
bjr1a
trans are the same as long as both are 46RE...In 2000 Dodge went to a different governor sensor......you can remove pan and if the gov sensor are the same then your ok.....
Brian
Old Jan 29, 2011 | 07:14 PM
rogershawn's Avatar
rogershawn
thanks
Old Jan 29, 2011 | 08:54 PM
wideglide01's Avatar
wideglide01
a guy I work with put 2000 durango trans in his 2000 ram,but I never did hear him say about changing anything to make this work.
Old Jan 30, 2011 | 10:26 AM
zman17's Avatar
zman17
That's because they were both 2000 models.
Old Feb 17, 2011 | 07:06 PM
rogershawn's Avatar
rogershawn
I decided to try the Durango transmission because I got an excellent deal on it. It fit perfect, everything matched up, no changes were needed. The only physical difference was the splash shield. I used the Durango splash shield and everything fit perfectly. Thanks again!
