Last edit by: IB Advertising
Browse all: Lighting
- Dodge Ram 2nd, 3rd, 4th Gen Aftermarket Headlight Reviews
Review and comparison of top products.
Halo Led projector lights melting. Help
Im losing patience and steam with these headlights.
Below you can catch up on the first few problems I ran into installing these lights.
https://dodgeforum.com/forum/chop-sh...-and-then.html
Now, less then 2 weeks later, they have melted.
Highbeams have melted the plastic. How do I know it was the highbeams? Because it is all I can run in order to see anything. I should of noticed this within the first few days, but the truck has been in the shop for the past 2 weeks and see's night driving for a total of maybe 15 mins a night when I have to go to work.
I have contacted the company and hopefully they stand by their warranty. Either send me something else, or give me my money back.
If I look into different lights, what does anyone suggest?
Edit, looking at those pics, it looks like maybe I was wrong, are those outer bulbs in a reflector or projector housing? Those are way too small to shed the heat. What wattage and type of bulbs are you running.
Get HIDs fire the projector lens and you won't have to over use the high beams.
I found your write up on how to do this on another post.
I was also told that the lights might of come with the wrong bulb for my truck? Which would be why my high beam light indicator is on all the time? Is this something you have heard of?
Outer bulbs? The blinker light? Or the headlight it self.
These are Voltex / Spyder lights and stated direct OE Replacement.
(94-01 Dodge Ram 1500, 2500, 3500
DOES NOT FIT 99-01 DODGE RAM PICKUP SPORT MODEL(9007 LOW BEAM AND 9004 HIGH BEAM) <This is what the dealer had stated for these headlights. Other then that no idea about the wattage. The only wiring I had to do, (well at this point my mechanic) was piggy back the led lights to the (drawing a blank... marker lights?)
Trending Topics
