Hood Latch Question
Old Mar 13, 2012 | 02:51 PM
stewie01's Avatar
stewie01
Default Hood Latch Question
So today I noticed that they hood release latch apparently fell out of whatever holds it and I found it in the bumper (pure luck it didn't fall out completely)
Anyways... of course the hood won't open now. So my question is, besides getting pissed and ripping the grille off, how do I go about getting the hood open so I can re-attached the release hinge thingy?
The hood will loosen up when I pull on the release handle, but it's still catching on something as it just barely won't open.
(Before my truck got hit and repaired, the old hood had a dent almost square in the middle from hitting a cow, the release handle thingy was gone and the hood would always open and close as it should)
Thanks.
Old Mar 13, 2012 | 02:57 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Release the hood from in the cab as usual, get a flashlight and look through the honeycomb and you'll see a lever up top in the middle. Use a long screwdriver or something and push up on that lever. Hold the hood down a little to take the pressure off the (safety latch lever) while you push up with said screwdriver.
Old Mar 13, 2012 | 03:25 PM
stewie01's Avatar
stewie01
Thanks z! The little plastic clip that holds the top of the latch in place is broke, time for some zip tie's.
Old Mar 13, 2012 | 03:28 PM
zman17's Avatar
zman17
How about a new plastic clip ? (better plan I think) And you got it open I assume?
Old Mar 13, 2012 | 03:34 PM
Does yours have the open recall for the secondary hood latch?
Old Mar 13, 2012 | 04:28 PM
stewie01's Avatar
stewie01
Zip tie will be a band aid until I get a new clip, just half of the clip broke.... But yes, it's open!
You lost me at open recall! After a google image search I'm on back on track, I think......
That's what I got, the red arrow point's to the backside of of the plastic piece that broke, which is why I was gonna use zip ties. Remember zman, certified REDNECK engineer.
