I need to replace front rotors and pads on my '98 1500, any recommendations? are ones available at Pep Boys for example adequate or should I order from Summit or Dealer?
Wagner thermoquiets are the best pads I've used. Whatever you do, don't get ceramic pads unless you like needing more space to stop and high pitched squeals.
great Sheriff, your reply just came in. Did get ceramic, gotta be better than metal on metal noise though. I'll get some earmuffs and increase my following distance
