Leveling Kit Installed!
Old Jul 17, 2011 | 05:29 PM
Default Leveling Kit Installed!
Took about 4 hours start to finish, most of that on the first side trying to figure out some clearance issues with removing/installing the strut. Found it is WAY easier if you remove the axle nut (for the 4x4 guys) so the axle can be removed from the hub and also remove the stabilizer bar. Makes it much, much easier to get the strut in.
1. Jack it up, remove the wheel, place on jack stands.
2. Remove the caliper and brake disk.
3. Remove the 3 top strut nuts (15mm, deep well or semi-deep well sockets recommended for all these nuts)
4. Remove the stabilizer link top (16mm) and bottom (15mm) nuts. You will need vise grips or open end wrench (13mm) to keep the link from turning while removing the nuts.
5. Remove the lower strut nut (24mm) and bolt (21mm).
6. Remove the tie rod nut (19mm) and tie rod end from the steering knuckle.
7. Remove the axle nut (for 4x4).
8. Remove the upper control arm ball joint nut (19mm) and separate the ball joint from the steering knuckle. (it is advisable to support the knuckle with a floor jack so it does not abruptly fall when the ball joint breaks loose.
8. Remove the strut assy.
9. Install is reverse. I ran into two issues: On the passenger side, could not get the front side of the strut to line up with the hole, was just barely off but enough that the bolt would not go through the strut hole. I had to file off about 1/8" deep by 1/4" wide of metal so it would line up.
The I ran into the fact that I had about 6" of distance between the upper control arm ball joint and the knuckle.
Big shout out to Maxtorq for his idea about using a chain attached to the floor jack and wrapped around the upper control arm, I used a ratchet strap instead, wrapped it around the upper control arm and put the hooks on the axle of the floor jack, this way, as you jack up the bottom control arm, it also brings the top control arm down and at the same time and keeps the truck itself from going up. Kinda squeezes the control arms together if you get the idea.
This was the 2" daystar over the strut kit (THANKS Ruger!!)
Thats about it, pretty straight forward. Couple of busted fingers and scraped knuckles. Dont forget to get an alignment. I'm going to get that done tomorrow. Truck sits pretty level. Time for bigger tires!!!
File Type: jpg
Old Jul 17, 2011 | 06:38 PM
cope4jerd's Avatar
cope4jerd
LOOKS GREAT! CONGRATS! can wait to see some bigger tires! good pics and great write up.......you for got one thing tho..... how did you tie up that caliper with speeker wire????????? hahahaha J/k man. took me about the same amount of time with mine about 3 hrs on the first side and an hr on the second after i figured out the daa gum first side it was easy. Excellent work.
Old Jul 17, 2011 | 08:05 PM
Blown287's Avatar
Blown287
Great work, looks good.
Old Jul 17, 2011 | 08:30 PM
ruger226's Avatar
ruger226
Glad to see that you finally got them installed.
Old Jul 17, 2011 | 09:05 PM
dakotaff's Avatar
dakotaff
It's about time that kit is installed! Looks real good, enjoy...
Old Jul 17, 2011 | 09:31 PM
popsnbeer's Avatar
popsnbeer
Nice writeup. I think the chain/ratchet strap idea is the best by far to get the thing back together! Looking at your pics makes me remember why when it's time for new struts I will be bringing the truck to a shop. Haha. Congrats, looks much better!
Old Jul 17, 2011 | 09:38 PM
here's a question....how bad do these things affect the alignment? What if I cant get it aligned for a couple of days? Extreme tire wear??
Old Jul 17, 2011 | 09:43 PM
Eimer123's Avatar
Eimer123
You should be ok for a couple days, its just gonna ride on the outside walls a little. I think I recall my caster camber being off about 1.2 degrees or something like that.
Dakkkota's Avatar
Dakkkota
i ruined a set on a car in 1 week
Old Jul 17, 2011 | 09:44 PM
Dakkkota's Avatar
Dakkkota
bodylift 285 75?
