3rd Gen Dakota general discussion This section is for general discussions about your 3rd gen Dakota. Non tech related Dakota threads belong here.
Center Console
Old Dec 10, 2010 | 02:27 PM
  #21
Six_Shooter's Avatar
Six_Shooter
If a strand is broken by stripping back the insulation, the solder creates a mechanical connection that strengthens that area.
Also the small contact between the Scotchlock and the wire strands causes a higher amount of resistance than the method I use, that in turn will cause heat, that in turn will cause a build up of corrosion, even when in a dry environment, due to the heat build up.
Scotchlocks should be removed from the market, that they cause more problems than they solve.
