I have a question for a friend....
so...a friend of mine wants to know where he could find an 08+ H.O 4.7
Lol does anybody know where....my friend...would go to find this? Only at the dealership?
So....where can someone get a hold on one of those 310hp 4.7s?
Ive looked a bit online, but can only find pre 08 engines. Also do you guys know if the motor mounts are different, if so not a big deal, I'm more worried about the tranny bolting up
Id be curious about the ECU, since mine is a 6spd, and the 08+ are only auto.
Did you blow your engine or something Mitsu?
Trending Topics
Nah, my engine is fine. But if I decide to go up in boost later on I would rather swap to an HO that is already forged rather than try to upgrade internals on my current engine.
By the way the sump tank worked perfectly
I can finally hit full boost and no oil will sip past the seals. No more smoke! Zero! nada!
This means that I am ready for tunning. This weekend im going to remove the charge pipes and intercooler to clean the oil that has accumulated there before the sump tank. After that, its finally time to go to 15lbs and wake up the beast with a custom tune! bwahahaha
I can finally hit full boost and no oil will sip past the seals. No more smoke! Zero! nada! This means that I am ready for tunning. This weekend im going to remove the charge pipes and intercooler to clean the oil that has accumulated there before the sump tank. After that, its finally time to go to 15lbs and wake up the beast with a custom tune! bwahahaha
