3rd Gen Dakota general discussion This section is for general discussions about your 3rd gen Dakota. Non tech related Dakota threads belong here.
Just got some new tires!
Old May 16, 2013 | 12:40 AM
ForkliftJeff's Avatar
ForkliftJeff
Default Just got some new tires!
I just got some new tires and had them installed today and I just feel like showing them off. It's a 2008 Dodge Dakota SLT Quad Cab V8 4x4. The tires are Cooper Discoverer A/T3. The stock size for my truck is 265/60 R18 but I wanted to get a bit bigger without having to do any modifications (stock suspension) so I went with a 265/65 R18. They look sweet but do rub a tiny bit when turning on the mudflap.
Here is a picture of the wear on the mudflap, it's hard to see. I might take the mudflap off and grind that area down so the tire doesn't hit it anymore. Or I'll just let the tire wear it down. Depending if I have time, I'm heading up fishing for the weekend.
File Type: jpg
Old May 16, 2013 | 09:02 AM
Looks great!
Old May 16, 2013 | 10:17 AM
italiandominator's Avatar
italiandominator
I had the same rubbing issue on my truck when I went up to 18" rims and a set of BFG's. I ended up using my dremel to trim off everything you have from that red circle in your pic to and including the bolt on the right. I was still having a rubbing issue in both the front and back when turning to extremes. so I ended up drilling a couple small holes and used zip ties to pull the wheel well liner back on both sides and got more than enough clearance to not worry about it anymore.
Old May 16, 2013 | 12:34 PM
dakotaff's Avatar
dakotaff
Yeah, a little trim and you'll be fine. Nice choice on the tires.
Old May 17, 2013 | 04:06 PM
JoeyDMG's Avatar
JoeyDMG
Yeah I had Discount Tire price them out for me for the 265/70R16's and they're about $885 with the certificates. Consumer Reports rated them the best A/T tire.
Old May 18, 2013 | 12:49 PM
jasonw's Avatar
jasonw
Site Moderator
Moved you to the general discussion section, since this isn't a tech question.
Nice tires, and nice truck. Can't always trust everything by Consumer Reports, as they go buy who owns their stock or buys them off a lot of times. Regardless though, those tires do look quite capable.
Old Jul 5, 2013 | 09:07 PM
JoeyDMG's Avatar
JoeyDMG
I ended up getting a set of these too in the 265/70R16. Just put them on and it poured. Probably ran through a few running washes that I shouldn't have, but the truck made it through with these tires. Can't wait to see them in dry.
Old Jul 6, 2013 | 01:09 PM
Beverly Stayart's Avatar
Beverly Stayart
Good choice -- the tires look terrific!
