3rd Gen Dakota general discussion This section is for general discussions about your 3rd gen Dakota. Non tech related Dakota threads belong here.
Question re 2008 4.7 Dakota
Old Oct 30, 2018 | 11:11 AM
OnPoint's Avatar
OnPoint
Default Question re 2008 4.7 Dakota
New member here, and first post. I did something I usually don't do, and that is make a fairly spur of the moment purchase prior to full knowledge of the product. I just got a great deal on a quad cab, 2008, 4.7 Dakota in great overall condition.
I come from a Chevy/GM background, so I don't have a lot of knowledge on these.
I'm looking for general suggestions on areas of concern for these models an owner would be advised to keep an eye on over time. Are there common problem areas for these one should keep in mind/eye on over time? Appreciate any suggestions. So far, enjoying the truck - it's a nice rig.
Old Oct 30, 2018 | 03:03 PM
northgator8's Avatar
northgator8
Front End!
Ball joints, tie-rod ends, sway-bar end-links. These fail with regularity. If they have been replaced with high-quality greasable components, you can get some mileage out of them. (that's if someone has greased them).
Otherwise, most don't have too much trouble if you keep the battery fresh. Low batteries seem to cause electronic/driveability issues.
Old Oct 30, 2018 | 03:11 PM
OnPoint's Avatar
OnPoint
northgator8,
Thank you. Yeah, that is exactly what I was looking for. Each make usually has its strengths and weaknesses, and some things to monitor over time. As a Chevy guy, I know what those are on those rigs, but this is my first Dodge truck.
Thank you very much for your reply. Good news - currently front end is tight and quiet. But I appreciate very much knowing that's a common wear area.
Old Oct 30, 2018 | 03:24 PM
Catch up on the required maintenance and keep up with the maintenance. Don't let it overheat. 4.7's don't like it when overheated. Aforementioned front end components. Struts are a good investment first thing. Monroe or Rancho. Not much aftermarket support out there for these trucks unfortunately. Treat it good and it will treat you good. Welcome to the forum. There's tons of good info on these trucks in the FAQ and main sections.
Old Oct 31, 2018 | 08:28 AM
Jaded's Avatar
Jaded
Some (like me) have a low speed vibration issue. Hard to notice when you first get it. Also listen to your front wheel bearings, they are known for their short life. I've gone through a set every 45k miles or so.
Old Oct 31, 2018 | 11:52 AM
OnPoint's Avatar
OnPoint
Great feedback, guys.
I very much appreciate it.
Old Nov 1, 2018 | 04:22 AM
philipat's Avatar
philipat
What sounds would I be listening for to tell me the bearings are going bad?
Old Nov 1, 2018 | 07:15 AM
Growling, humming, scraping.....depending on how bad they are.
Old Nov 2, 2018 | 10:05 PM
philipat's Avatar
philipat
Good to know...thanks.
