3rd Gen Dakota general discussion This section is for general discussions about your 3rd gen Dakota. Non tech related Dakota threads belong here.
Dropping into 4WD by itself
Old Dec 21, 2025 | 07:17 AM
  #21
Dakota Bloke's Avatar
Dakota Bloke
Originally Posted by Dakota Bloke
Pulling the fuse has cut power to the T-case, as it doesn't engage 4wd anymore. There is no sound coming from the motor that I can hear, maybe if I listen up close it possibly is whining?
When I get the chance I will disconnect the feed from the shift motor. This may stop the 4wd light from illuminating up on the dash?
Just adding that I had a free car ramp last week and got the truck up in the air, disconnected the plug on the TC motor. The 4wd/svc light stays on all the time now, but with the fuse removed there's no issue with it dropping into 4wd by itself.
Will up date when I have bought the new TC motor.
Old Jan 2, 2026 | 12:58 PM
  #22
Dakota Bloke
Latest up date, I have now ordered, received and fitted the new TC motor and can report that I have all the 4WD back again. Bit of a faff fitting it as the front driveshaft was in the way, but once the rear transmission mount was unbolted and the transmission raised it then made easier access.
Now I can get on with the Ram........
Old Feb 15, 2026 | 06:55 AM
  #23
Dakota Bloke
Just to close off on this subject. The TCM was at fault.
When I removed the existing one It was made in China.
Trouble is, so was my new replacement
So far so good.
Old Feb 15, 2026 | 09:06 AM
  #24
Everything is made in China these days.......
Old Feb 15, 2026 | 10:46 AM
  #25
Dakota Bloke
Some good, some not so good though prices are good.
