DIY Homemade intake
Old Apr 11, 2007 | 09:31 PM
Cuban11182's Avatar
Cuban11182
Default DIY Homemade intake
http://www.reubengathright.com/DakAir.html
How does this look
Old Apr 11, 2007 | 11:42 PM
nowick's Avatar
nowick
Default RE: DIY Homemade intake
stick with the pros at K&N they do airflow tests and have the best design. they might look the same but the shape and size is all factored into it. It looks like the home depot prodesk built it!
Old Apr 12, 2007 | 11:32 AM
luvmydak's Avatar
luvmydak
Read the disclaimer again at the bottom after the install instructions.That says it all. Spend the money and get a real CAI kit.
ORIGINAL: Cuban11182
How does this look
Old Apr 13, 2007 | 12:51 AM
Cuban11182's Avatar
Cuban11182
did you do the same thing? with the abs plastic?
Old Apr 13, 2007 | 02:03 AM
Altair's Avatar
Altair
Dak attack!
ORIGINAL: ericemery
I have a DIY intake that the g-tech says is as good as my friends K&N. his truck gained 6 at the wheels according to the g-tech. I gained 5. I spent 50, he spent 249...
Have you ever had your truck dynoed? It would be interesting to see the hp and torque curves compared to the K&N. The ideal comparison would actually be if you could borrow the K&N system from someone and do a few runs with yours and a few runs with the K&N on it but that's a lot of work.
Also, did you by chance make a post of how you made the intake? I'd be very interested in seeing that if you did.
Old Apr 13, 2007 | 12:28 PM
MonkeyWrench4000's Avatar
MonkeyWrench4000
I think the BEST budget solution is to spend the 99.95$ on the Airraid modular intake tube that connects to the stock box, and then get a drop in K&N filter for the box at walmart, like $25 by me. You get the ebst of all worlds. A plastic intake tube, a K&N filter thats in a box for off-road and water protection. The box that holds the filter itsself cant possibly cause restriction.
Old Apr 13, 2007 | 12:38 PM
Casper50's Avatar
Casper50
Go take a look at your air filter box and tell me where it is sucking are in and tell me it's not restricted. There is a member on here though that took out that small inlet hose and put like a 4 inch pvc tube in. That's the way I plan on doing it and is the smartest way of doing it if you don't want to hassle with running the intake to outside of the engine bay.
Old Apr 14, 2007 | 01:30 AM
herkguy's Avatar
herkguy
Cuban here is the airaid Jr setup with facotry box and larger feed tube.
[IMG]local://upfiles/57176/06B57407564E494EAC5163670BD4A722.jpg[/IMG]
