Custom Sway bars...
Old May 18, 2007 | 09:30 AM
ThunderStick's Avatar
ThunderStick
Default RE: Custom Sway bars...
Summit Racing does not list aftermartket sway bars for 3G Daks.
A stiffer sway bar would make a tremendous difference in the ride of these 3G trucks. They're way too soft for off- roading and towing.
In another thread, I've harped about the **** poor quality of the OEM shocks as well and the fact that no one is currently making an aftermarket shock. (In development, we're told).
My truck bounces and rocks way too much and I hope you aftermarket manufacturers get on the stick and produce this stuff. I'm gettin' sea-sick ridin' in my '05 Dakota that has 21,000 miles.
[sm=feedback.gif][sm=americanasmiley.gif]
Old May 18, 2007 | 11:39 AM
rookie's Avatar
rookie
are these things really called sway bars? Aren't swaybars on the bottom going from A-arm to A-arm. I think (unfortunately) that springs and shocks are the best way to stiffen any ride. As mentioned befor the level kit does help for some reason. My truck is much stiffer up front. it is a bit bouncy still.
Old May 18, 2007 | 11:50 AM
rick4dak's Avatar
rick4dak
Sway Bars (technically Anti-Sway bars) will limit the truck from leaning as much while cornering. They really help with on-road handling but detract from slow-speed off-road handling because they can hold a tire off the ground when it should droop into ruts or when going over rocks. That's why off-roaders use quick disconnect end links on their sway bars.
There used to be a company called Addco or something similar that made custon sway bars.
Old May 18, 2007 | 12:01 PM
Casper50's Avatar
Casper50
ORIGINAL: rookie
No, they are talking about a strut tower brace. All they do is reduce thebody roll of a vehicle. They do good if you plan on racing your vehicle but I personally wouldn't put one on my truck because I don't use it for that. It was great on my last car though. It would probably help with all of the mountain driving that I do but I don't speed through the mountains because I like to take in the scenery. I guess the choice to get one would depend on what your driving habits are.
Old May 18, 2007 | 01:40 PM
Frenchy's Avatar
Frenchy
I like high speed cornering. :-)
I haven't had a problem with mine, maybe it's the 6spd and having high RPMs through the twisties... I want to stiffen the body roll though for sure.
Old May 18, 2007 | 01:50 PM
Altair's Avatar
Altair
Dak attack!
ORIGINAL: ThunderStick
Tell me about it, I just got mine back from the dealer yesterday after having them look at the suspension because it bounces so much. The tech that took it out and drove it told me that mine is actually a little stiffer than most of the daks he's driven so they sent me home empty-handed One of my friends won't ride with me anymore, says it gives him motion sickness.
Old May 18, 2007 | 02:43 PM
DakotaStone's Avatar
DakotaStone
I feel like that when I hit bumps in the road, or take a corner with mine, it doesn't feel as tight as I want it to. Even though I have AWD, it handles pretty good, but if I want to do some competition stuff with my truck, I want to take whatever turn, slalom, etc., with without feeling like my truck is going to slide all over the road, or roll over on me.
I know that lowering it a couple of inches would help on handling, but right now, making me a couple of sway bars would be a good inexpensive start.
Old May 18, 2007 | 03:09 PM
Altair's Avatar
Altair
Dak attack!
Stone, I'm a little confused which bars you want to make. Are you looking to make the sway bars that go on the suspension underneath or strut bars to go on top in the engine compartment? Sway bars would be harder to make but would probably have a much greater effect.
Old May 18, 2007 | 04:10 PM
rookie's Avatar
rookie
what he said.
Old May 18, 2007 | 04:32 PM
superdak05's Avatar
superdak05
my truck came from the factory with both frt and rear sway bars. but the back one is kinda whimpy.
