IAT relocate...again
Old May 21, 2007 | 12:12 AM
trucky's Avatar
trucky
Default RE: IAT relocate...again
i got a half inch drill bit because a dakota forum said the new whole needs put at 1/2 inch or 7/16...so does that mean i need a half inch plug. that would make sense to me. or do you not remember
Old May 21, 2007 | 12:15 AM
Frenchy's Avatar
Frenchy
Oh wow, didn't even see that!!
Old May 21, 2007 | 12:20 AM
superdak05's Avatar
superdak05
back up for a second. tell me what you are doing now. are you gonna plug the old hole or drill a new hole? if you are gonna plug the old hole it is a 1/2 inch plug. i just went outside and measured it
Old May 22, 2007 | 06:42 PM
trucky's Avatar
trucky
http://www.blackshireserver.net/Ohio...d%20Tricks.pdf
go under the IAT relocate section and it says plug with 1/4 inch but drill 1/2 inch. made no sense to me.
logic says...drill new hole at 1/2" and plug old hole at 1/2". so i dunno whats up with that but its the same on all forums ive searched.
Old May 22, 2007 | 06:47 PM
superdak05's Avatar
superdak05
drill the same exact hole that was there for the factory sensor. and use the rubber groument that came with it to install. that why i just put it in the filter. i slip off the filter and placed the whole sensor in the cone. slipped it back into position and left it.
Old May 22, 2007 | 06:52 PM
superdak05's Avatar
superdak05
the 1/4 inch plug is if you are using the factory intake system. seeing how we have the k/n system this thread does not apply. your system came with the rubber groument correct. by drilling the 1/2 inch hole you will need to insert the rubber groument into the hole then insert the iat sensor into the groument.
Old May 22, 2007 | 08:18 PM
trucky's Avatar
trucky
...things make sense again. i dont have that gromit tho. if i go to home depot do i say.. "i need a half inch rubber gromit" or what..cuz i cant find things worth a crap
Old May 22, 2007 | 10:11 PM
superdak05's Avatar
superdak05
yes but pick up a couple different sizes. just in case.
