tires tsb
Old Jun 11, 2007 | 07:42 PM
WIZARD's Avatar
WIZARD
Default tires tsb
anybody see this or have any more info on it found this on th "nhtsa" website a few references to it on other sites, but not what it says, or even if it is a mistake.the mechanic in the next town over that i work for has the snap on shop key program and that does not even list it.
TSB No.: 06006
NHTSA No.: 10020759
TSB Date: November 16, 2006
Failing Component:
Tires
Description of Summary:
Shakes while driving on smooth roads and/or pulsates while braking.
Old Jun 12, 2007 | 12:16 AM
Bionicrooster's Avatar
Bionicrooster
Default RE: tires tsb
Maybe explain my trucks vibrations during braking.
Old Jun 13, 2007 | 12:38 AM
El Capitan's Avatar
El Capitan
I took my '05 in for brake vibrations (only 10,000 mi.). On the first visit, they replaced the "badly worn" front rotors for 200 bucks.
But the truck still vibrated when braking, so on the second visit they found a tsb (tsb 05-002-06) to replace the rear axles and rear brake shoes.
This made the vibrations go away, but I noticed that my brakes felt really soft after that....like I felt the pedal was going too close to the floor. Is this normal after getting brakes changed???
Old Jun 13, 2007 | 02:13 AM
vandutton's Avatar
vandutton
You can probably bleed the brakes and solve that problem. That should solve the feeling of the pedal going in too far.
Old Jun 13, 2007 | 01:57 PM
06dak's Avatar
06dak
Does anybody know what years/VINs the axle TSB covers?
My truck vibrates bad under long, slow braking (think slowing down for a highway exit/entrance ramp). I havn't taken it yet to the dealer since it's got 17.5k on it, and I have a feeling they'll try the "brakes only up to 12k" thing before even trying to fix it.
Old Jun 13, 2007 | 04:46 PM
Bionicrooster
06dak, that is exactly the problem I have.
