throttle body
the pic that i have i stole from the other website www.dodgetruckworld.com so i can say that the spacer is not mine. and yes they are a paper weight
So if the HO has a higher lift or performance cam from the factory I wonder if the factory TB is a true 68mm or coned and would a true 70mm from fastman be the correct choice for the HO.
all the 05 an up tb are the same size and coned ,just by opening up the tb with the h.o. motor will increase the performance some. its not a bad idea to do it. plus all the intakes are the same
Guest
Posts: n/a
yeah, H.O. is just cammed and Computer work... they are less than the 206 cams, but still a better cam than the non-HO (like I got shafted with ; ) I may start to look at internals if I begin my quest for 300rwhp... I am still contemplating the repercusions of such an endeavor.
Dakota, did you happen to find out whatDans ecu reprogram does and what it costs? I just figured out that the fastman lives right here in Minneapolis which makes getting ecu work done much more appealing. [sm=icon_rock.gif][sm=icon_rock.gif]
Guest
Posts: n/a
well, I am not sure if this will help or not, but if you have any questions, why not ask the guy?
http://www.thefastman.com/contact.asp
I am going to be looking into some top secret mods, and I might have to have some work done by him... :-P
Well I studied the pics superdak05 posted and swapping throttle bodies seems like a good idea. I see what you mean about cone shaped.I wasn't planning on doing a lot of engine stuff other than adding headers to the stuff I already have (elec fan, intake, exhaust) but after reading all these posts I think I will do the throttle body and maybe the 180 t stat. I am looking for horsepower and increasing gas mileage which I know the gas mileage part may be tough to do.
ORIGINAL: herkguy
