hoods
Old Jul 25, 2007 | 10:30 PM
JAB02LHS's Avatar
JAB02LHS
Default RE: hoods
ORIGINAL: superdak05
wtf is composite. is it like the press board that they make plywood out of? or is it fiberglass? i would rather have a steel hood. then some flimsy piece of card board.
My '04 Tbird has composite hood trunk and front fenders. It works great, the car was in a hailstorm in Texas while new on the lot. The rear fender , windshield frame and driver door got baseball size dents but the composite was fine!
Old Jul 25, 2007 | 11:00 PM
Altair's Avatar
Altair
Dak attack!
Default RE: hoods
ORIGINAL: ericemery
its as close to carbon fiber as you can get without using actual C.F... its a way to make fiberglass stronger in flat areas. (where its weakest.)
I wouldn't be surprised it they use metal mesh in the middle of those hoods...
So would you guess it to be lighter or heavier than the stock hoods?
Old Jul 25, 2007 | 11:24 PM
superdak05's Avatar
superdak05
Default RE: hoods
how would you go about painting it? if it is a special composite then it might cost and arm and a leg to color match the truck
Old Jul 25, 2007 | 11:34 PM
superdak05's Avatar
superdak05
Default RE: hoods
i was just on my other site and a ram owner just received his composite hood went to the local shop and they wanted to charge 600.00 to prep and paint the hood. and it was off the truck. does this sound correct for composite? if so you can forget about me purchasing one. i would be better off getting a scoop and pop riveting on.
Old Jul 26, 2007 | 12:04 AM
4x4QC06V8DKTA's Avatar
4x4QC06V8DKTA
Default RE: hoods
well the hood should come preped and ready for paint so there shouldn't be any need to have to prep it before paint...so yeah and its a good hood had one on my 1st gen and we had a hail storm...everything but my hood was dented like ****! so it'll do you good!
Old Jul 26, 2007 | 11:35 AM
4x4QC06V8DKTA
Default RE: hoods
hey i'm starting to double guess my self...which hood looks better?
The STS HOOD
OR The RAM AIR HOOD???
www.carhoods.com
Old Jul 26, 2007 | 12:00 PM
fbnzippy's Avatar
fbnzippy
Default RE: hoods
Definately the Ram Air hood for me. But then, I am a Pontiac Nut as well And as far as painting, Composite is the same as Fiberglass. They have applied a Gel coat to the hood, so regular painting techniques for painting
Old Jul 26, 2007 | 06:44 PM
superdak05's Avatar
superdak05
Default RE: hoods
if we get these hoods. will we have to swap out the factory hood springs to a lighter spring? or will the factory ones work?
