Power Wire & CEL
Old Sep 29, 2010 | 05:50 PM
  #41
actually the weather finally turned fall around here so I guess installing it now when the daytime temps are around 60, it really wont do any good correct?
Old Sep 29, 2010 | 06:20 PM
  #42
WTEBOY703's Avatar
WTEBOY703
okay i'm still a little confused...what happened to what they said "instals in lessthen 60 seconds" my brother hs one on his RAM and he said all he did was unplug and plug in is this no true! i'm so confused i'm not splicing into wiring
Old Sep 29, 2010 | 06:31 PM
  #43
rengnath's Avatar
rengnath
It will make the air/fuel mix richer regardless of the season. You'll probably get peak performance around the 40-60 degree, imo. I love going cruising on fall nights.
The actuall 45 degree power wire will install in less than 60 seconds. If you want to save $44 and know how to splice in to one wire and put in a resistor, then what is described above is what you have to do. It will take you 3 minutes instead of 1, but they do the same exact thing.
Old Sep 29, 2010 | 06:35 PM
  #44
WTEBOY703's Avatar
WTEBOY703
oh okay...i thought you were sayin when you buy the power wire from Air Ram you have to do that i was like Fudge that! I was gonna say i just wasted 45 bucks like 2 months ago when i bought it! kewl no worries then i'm just going to hook up at the intake and then into theother position and be done! to easy!
