180 degree thermostat question
Old Aug 6, 2007 | 07:34 PM
kingsaffey's Avatar
kingsaffey
Default 180 degree thermostat question
i recently intalled the jet chip stage 2 in feb. i felt a great increase in power, tq and the gears hold and switch smoother. it says 180 degree thermostat are recommended but not necessary. what does it do with the chip?
Old Aug 6, 2007 | 09:38 PM
LB's Avatar
LB
Default RE: 180 degree thermostat question
Wat octane gas do you use?
LB
Old Aug 6, 2007 | 10:01 PM
superdak05's Avatar
superdak05
a cooler running engine will produce a little more power. plus it helps with pinging if you run cheap gas.
Old Aug 6, 2007 | 10:03 PM
kingsaffey's Avatar
kingsaffey
93 octane i run in it
Old Aug 6, 2007 | 10:26 PM
superdak05's Avatar
superdak05
thats what i run.
Old Aug 7, 2007 | 01:36 AM
kingsaffey's Avatar
kingsaffey
what is pinging exactly, never had it b4
Old Aug 7, 2007 | 07:54 AM
superdak05's Avatar
superdak05
you get it under hard exceleration while going up hills using cheap gas. if you have ever heard a rod knock before thats what it sounds like.
Old Aug 7, 2007 | 08:30 AM
graythang's Avatar
graythang
Does the ECM mind the stat change? It seems every thing that is done the ECM knows about it and you never know how it’s going to react.
Old Aug 7, 2007 | 08:32 AM
superdak05's Avatar
superdak05
i have no issues with my truck. really likes the cooler stat and responds well, with all the other mods.
