shift kits
Old Mar 20, 2008 | 07:48 PM
Racinartist's Avatar
Racinartist
Default RE: shift kits
What's the other upcoming option?
Old Mar 20, 2008 | 11:09 PM
turbot_bird's Avatar
turbot_bird
Its easy, drop the pan, Pull filters off, Unplug main harness from tranny, drop valve body. Put it on bench, pull off side plate, replace springs and L/R valve in correct fasion as pic on instructions, put on new sideplate, and reasemble. If you have a programmer dont add resistor if no programmer install resistor in wire on passenger side of tranny.
Old Mar 20, 2008 | 11:35 PM
LB's Avatar
LB
ORIGINAL: rick4dak
Have any of you put the Transgo kit in ? If so, has it made an improvement in shifting ?
There is going to be another option in a month or so but it's a lot more expensive so before making a choice, I would like to know anyone's actual experience with the Transgo kit.
Ya, what is the other option? Are you referring to the Sharadon stage II or III valve body for $325 The feedback on these is awesome. http://sharadon.com/sdparts.htm
Don't leaveus hangin like that!
LB
Old Mar 21, 2008 | 12:40 AM
Frenchy's Avatar
Frenchy
Other option....
Get a Getrag 6spd...
Old Mar 21, 2008 | 12:45 AM
turbot_bird
ORIGINAL: Frenchy
Other option....
Want to come convert mine???????
Old Mar 21, 2008 | 01:10 AM
Frenchy's Avatar
Frenchy
You got 6 grand?
Old Mar 21, 2008 | 01:17 AM
turbot_bird
lol no but I know where there is a 6 speed.......... There is this red sport with a black custom grille.......
Old Mar 21, 2008 | 01:48 AM
Frenchy's Avatar
Frenchy
Wiiiiiiiierd, never seen said truck...
Old Mar 21, 2008 | 09:50 AM
rick4dak's Avatar
rick4dak
TCI (used to be Torque Converters Inc) has an electronic controller and will have the wiring harness ready in a month or so. I expect the controller to allow tailoring the line pressure and shift points but have not received the documentation yet.
