Finally found a place for a sub!
Old Sep 6, 2007 | 09:43 PM
nowick's Avatar
nowick
Default RE: Finally found a place for a sub!
did the same thing but faced ther sub foward I am happy with the set up sounds good!!
Old Sep 6, 2007 | 10:41 PM
Frenchy's Avatar
Frenchy
Hahahaa, oooh ya... forgot about that sub thing in the headunit....
DOY!
Old Sep 7, 2007 | 08:31 AM
HuffDaddy's Avatar
HuffDaddy
Nowick, what kind of sub are you running? I like your setup,I considered going that route but with the excursion of the JBL sub I was worried about it hitting my console.
Funny that in all of my searches I never found that one.
Old Sep 7, 2007 | 05:00 PM
HuffDaddy's Avatar
HuffDaddy
How the heck do you remove the rear seats? That back bolt looks difficult unless.....no way, is it the body mount going all the way up and through?
Old Sep 8, 2007 | 01:26 PM
BAdassR/T's Avatar
BAdassR/T
is it possible a 10' could fit there or no?
Old Sep 9, 2007 | 10:11 AM
HuffDaddy's Avatar
HuffDaddy
A 10" would not fit where I put mine unless you made it way higher than the centerconsole then you run intointernal volume constraints, my box is made of 1/2" Mdf (braced thoroughly). I usually use 3/4 MDF but even going to the 1/2" I came up with a .39 Cubic Ft of interior space which is right in the reccomended range for my sub. Most 10's start at .50 Cubic ft or more for a sealed enclosure. On another note I did come from a commander with 2 12"s in optimized ported enclosures and while this8" does not thump outside the vehicle thesound inside is powerful. I dont mis the 12"s too much. Definately impressed with this little guy.
