just installed a roll control (line lock) on my truck and its awsome!!! just hold it for a second or two and it will spin like nobodys business! extreme holeshots to say the least all for 75 bones
no a line lock or roll control locks just the front brakes (like dragsters use to burn out before they stage) you depress brakes hold down a button and release brakes and the front stay locked until you let go of the button!! it only takes a second or to to get tires moving then you release the button and you burn out like a mo-f-r its a trip!!!!!!!!!!
it was 75 bucks plus a few bucks for a small leng of brake line and 2 fittings ill get some pics when my camera gets home
RE: who likes burnning rubber?
Where did you order it from? and I am still not sure how this is much different from brake torqueing<---(sp?)
We must apply a fair amount of rear brake pressure with the depression of the pedal?
there is zero pressure on rear brakes thats how it works, it holds the front brakes and frees up the rear! it is basically a valve that keeps the front brake line shut and lets the rear open only ill get a pic shortly to explain more!
oh you meant without locker im sorry yeh its way more than i thought too i think its because our rears are anti-lock
