Rough country lift!!!!!!!!
Old Nov 5, 2007 | 06:24 PM
  #101
pro4x4's Avatar
pro4x4
Default RE: Rough country lift!!!!!!!!
What about height adjustable struts like rancho makes? I did contact them about making them for our trucks and got the usual answer no way. But rough country could take the lead and make them. This way you don't need to mess with spacers just pop the old strut out and put the new one in. Give it a range of 1 to 2 inches of lift and there you go. I don't know this is really getting rediculous. I really want a 3 inch lift but don't want a body lift unless I could get a 1 inch body lift and then use the spacer kit. How about rough country making a 1 inch body lift.
Old Nov 5, 2007 | 06:35 PM
  #102
RCXRAIDER's Avatar
RCXRAIDER
well as for the struts like i said if a company can make spacers cheaper they will, and we dont make body lifts, we are looking into it but thats in the far future
Old Nov 5, 2007 | 10:57 PM
  #103
Handy05's Avatar
Handy05
ahhh the pain i just want a 3 inch lift. I want to be able to run 285s.
Old Nov 6, 2007 | 04:57 AM
  #104
Cuban11182's Avatar
Cuban11182
Well maybe we will be in luck...who knows? http://www.dodge talk.com/forums/showthread.php?t=179475
Old Nov 6, 2007 | 10:46 AM
  #105
Altair's Avatar
Altair
Dak attack!
ORIGINAL: Cuban11182
http://tinyurl.com/yty2tb
FYI to post stuff like this you can just go to www.tinyurl.com and make one of these links out of it
Old Nov 6, 2007 | 01:40 PM
  #106
RCXRAIDER's Avatar
RCXRAIDER
2WD 2.5in. KIT IS OUT, part number 397s, 199.00 contains spacers, rear shocks blocks and u-bolts
Old Nov 6, 2007 | 02:20 PM
  #107
Dak_in_Black's Avatar
Dak_in_Black
Ok, so now the 'mall crawlers',I believe that is what someone called them (nothing personal guys) have something...hopefully the rest of will not have too long of a wait...
Old Nov 6, 2007 | 03:23 PM
  #108
AdidasCJ's Avatar
AdidasCJ
ORIGINAL: Dak_in_Black
Old Nov 6, 2007 | 04:39 PM
  #109
mikey111k's Avatar
mikey111k
Just to make sure i understand what the kit is i have a few questions. The front spacers are like the trailmater spacers which preload the spring or like the Truxxx kit which mounts on top? Is the 2.5" lift front and rear so the truck will still keep the factory rake or is it different front to back? if it is different what size blocks are in the back? Thanks
By the way im a 2wd guy and i agree that the 4wd drives need a good lift too but dont hate on us 2wd guys, sometimes that is all your dealer has and you cant afford the extra cost for the 4wd (such as me). wells thanks roughcountry for coming thru with this and keep going so we have some more options.
Old Nov 6, 2007 | 04:46 PM
  #110
RCXRAIDER's Avatar
RCXRAIDER
we tried both styles decided on the top mount like the truxxx, it maintains factory ride quality in front, its 1.5 inch blocks in rear, it still has the rake but its not as bad, also it comes with hydro shocks for rear, you can get the front spacer only for 99 bucks, but it will give it a prerunner look, or a reverse rake, i couldnt stand riding like that for the days they had it on my truck but if you like it, its an option
