mileage odometer work-around???
Old Nov 8, 2007 | 10:59 PM
BACKnBLACK's Avatar
BACKnBLACK
Default mileage odometer work-around???
I was wondering if anyone would know how to disconnect the odometer or know a work-around to show less mileage when time to turn in the truck at the end of the lease. My Dad is due to turn his Dak in soon and doesn't want to go over the mileage, which will be near impossible without a work-around. Has anyone ever done it. Will it screw with the PCM? Will the check engine light come on? etc.
Old Nov 8, 2007 | 11:03 PM
Nicegy525's Avatar
Nicegy525
Default RE: mileage odometer work-around???
its illegal for one thing. and another thing, digital odometer mileagesare stored in the main computer so unless you can re-program the main computer there isnt any way. the old analog odo's were alot easier to screw with.
Old Nov 8, 2007 | 11:06 PM
BACKnBLACK's Avatar
BACKnBLACK
I thought so, but I thought I would ask.
Old Nov 9, 2007 | 06:36 AM
sdsdsd's Avatar
sdsdsd
I can't believe you would even ask us to be dishonest!
Old Nov 9, 2007 | 08:28 AM
mb18's Avatar
mb18
Whatever you do, don't tell us about it. That's called evidence...
Old Nov 9, 2007 | 11:50 AM
QCDAKblue's Avatar
QCDAKblue
No really fair to next owner! As a person that got scrwed by a dishonest owner please just pay the difference. I had a 95 M3 BMW at time of purchase showed 60k on the dash but when a BMW tech worked on the car the computer showed over 100K. The car ran perfect and looked great but it was still a dirtbag move (I found this out 2 years later, I only put 22K on it at that time). I had the dash reprogrammed to reflect accurate miliage, so I sold it honestly. Good thing car like that held its value so I really didnt loose much money.
Old Nov 9, 2007 | 05:57 PM
turfgrass's Avatar
turfgrass
Somebody told me there is a way to do it, start the truck and click the key back just a touch to keep it running, this disables the speedo, all accessories including ABS, (you cant even adjust the heat or vents, windows or door locks) and will cause your Check engine light to come on, and throw code U1120 (Lost wheel distance). It onlyu works for so long then it starts counting your miles again. I think at most it can be used for 100 miles then it no longer works.
Also there is a wiring diagram for the wheel distance sensor in the service manual so you could disconnect that, not sure how easy it is as reading electrical diagrams is not my thing.
But hey that would be stealing of miles and I do not condone that type of behavior!!!
On a side note if you turn the key on and off about 3 or 4 times ending with on your engine code will be displayed in the odometer.
Old Nov 9, 2007 | 05:58 PM
superdak05's Avatar
superdak05
what we use to do in the old days, was put the vechicle up on jack stands and open the hood. tie a string to the coil wire in case vech. fell off the stands it will kill the engine. while up on the stands we would put the vech. in reverse, this would make the odometer go backwards taking off the mileage. dont think the new ones could do that.
Old Nov 9, 2007 | 10:43 PM
BAdassR/T's Avatar
BAdassR/T
ah i hate miles on cars feels like they go so fast...............wish they didnt go so fast
