NEEDED: Pics of aftmkt Bumper Guards
well ive done leafs all around & that was the plan because they're the easiest. I was first thinking maybe some the Ram axles would go well under there but they'd be too big and overkill IMO. So now have my heart set on Grand Cherokee axles..for several reasons: [ol][*]keep F/R axles from same vehicle-it'll make finding parts later easier[*]they're pretty stout axles and have lots of aftermarket support[*]come with discs F/R brakes & no issues with ABS (fittings may need some adapting) [/ol]But when I looked deeper into the truck the frame does some weird stuff on the front. It goes from box, hexagon shaped, and then cylindrical. And all this is from the back of the strut to the bumper. I could weld up some brackets to the front but I figured that funny frame has a lot to do absorbing impacts. So I'd loose my suspension if I did do leafs.
So coilovers would be the easiest and least time consuming. There's a calculator out on the net you can find to help determine the ideal length of your long arms if you four link it(the front that is)
But I'll only do this after I get my jeep up and running again with a new wiring harness(January hopefully) and my warranty runs out. But should a good lift come out for our truck, enough to clear 33s or 35s I'd rather waste my money on it then put my truck outta service for a couple of weeks.
But to answer your question...no I've never done a solid axles swap but I have swapped axles enough F/R to feel comfortable attempting it...when I first wrote that sig I had the leaf spring idea in my head. Coils would be a bit more work by myself. I'd only need to address steering which can be addressed with hydraulics, driveshafts, and brakes.
That's some good information.Because to tell you the honest truth I would love to get a solid front axle when I convert to 4x4. So the grand cherkoee axles are pretty good choices for our trucks? That's good to know, I'm trying to get in touch with someone that builds rock crawlers, should have enough experience to cut off my front suspension and put on a solid front one. I'm just not a fan of the independant suspensions ![Big Grin](https://dodgeforum.com/forum/images/smilies/biggrin.gif)
Hope it goes well. Maybe you can find most of the parts from a junkyard or ebay.
