KYB may support new front shocks!!!
#21
RE: KYB may support new front shocks!!!
In the latest issue of 4 wheel and off road mag they have a story on a 1500 ram an 07 or 08 I think and they are installing the rancho quick lift struts. The struts look exactly like the ones on our trucks so why the heck doesn't rancho make the quick lift struts for our truck. They may have to do a little tweeking for our trucks but I would rather have the quick lift struts than using spacers.
#24
I do not know if this is any help ,but Monroe make a replacement strut/shock for the 2005 Dakota, should be the same for the 2006 ???? the link is below.
http://catalog.tenneco.com/monroe/shockSelector.do
SENSA-TRAC® STRUTS Part # 71100
#25
unfortunately that info has been known since at least July.. Don't think there is a single person here or maybe anywhere else that has ever been able to put an aftermarket (correct fit)front shock on these trucks yet.
ORIGINAL: VA Dakota
#26
More talk about shocks, still no action...Still no aftermarket manufacturer has heeded our call.
I'd be willin' to wager that my truck will be eligible for "antique" tags before"they"get a decent shock to us.
I still don't see why it has taken so long for the aftermarket guys to rectify this long-running and continuing saga/problem.
Steamed in Maryland. [sm=rant.gif]
#27
I've been comparing our struts to several other trucks and ours is a completely diff design. Most struts have the typical O mount at the bottom of it. As some of you are probably aware ours is an open C design. Not very common which makes finding a swap from another vehicle pretty hard...So far all the newest trucks with struts do not use this design.
#28
#30
