can a black dakota plastic bumper be painted?
Old Jan 9, 2008 | 06:05 PM
  #21
pro4x4's Avatar
pro4x4
Default RE: can a black dakota plastic bumper be painted?
You can do it. I did Just sand the bumper and spray an adesion promoter. Then prime it and paint it. Then clear coat it. My bumper has held up for a year so far with no chips. It is a lot of work though and make sure you clean it good and wet sand after each color coat and buff out the clear coat for a glossy finish. It will be cheaper and as long as you prep it right will last forever.
Old Jan 9, 2008 | 09:07 PM
  #22
cramerica's Avatar
cramerica
The bumper has a little texture to it...do you sand it until it's smooth to the touch, or just to scuff it up a reasonable amount?
Old Jan 9, 2008 | 09:17 PM
  #23
Frenchy's Avatar
Frenchy
Sand til smooth.
At least, I would...
Old Jan 10, 2008 | 05:58 PM
  #24
pro4x4's Avatar
pro4x4
I just scuffed it up real good. You can still kind of see the texture on my bumper. If I did it again I probably sand it more or you could spray more coats to fill in the texture. I hate painting I don't have the patience for all the wet sanding in between color coats and all the buffing but it came out ok and has held up pretty good.
Old Jan 11, 2008 | 04:50 PM
  #25
shocker88240's Avatar
shocker88240
anyone have a website where i can just buy the paintable front and rear bumper?
i want to get rid of that chrome strip on the front bumper too....
Old Jan 11, 2008 | 09:43 PM
  #26
Frenchy's Avatar
Frenchy
So, just pull it off, bondo the holes smooth, and then paint it, it'll save you a lot of money... maybe not time... but money.
