Need opinions!!! CAI problems
Old Jan 11, 2008 | 10:05 PM
billcat's Avatar
billcat
Default Need opinions!!! CAI problems
Last Saturday, i changed the plugs (autolite 5224 and i know) and put a K&N CAI on all with out trouble, plugs took a little while but, CAI was a breeze especially with the instruction. Started Truck and over next two days drove 60-70 miles without any problems, then the check engine light came on. The truck ran"ok" but not as good as i thought it should with updates. Took to my mechanic which said it was a "mechanical glitch". Got the truck back, ran great for 60 more miles then engine light came back on? its an 05 with 47k v8 4.7 50 series flowmaster, be for cai i had just a kn replacement filter. Any suggestions(other than not going with autolite3923) on what the **** the problem is.
Old Jan 11, 2008 | 10:36 PM
Altair's Avatar
Altair
Dak attack!
Default RE: Need opinions!!! CAI problems
Go to Autozone and pull the code with their codereader. It's free and will probably give you an idea what's going on.
Old Jan 12, 2008 | 02:15 AM
jtswkd's Avatar
jtswkd
Maybe the new filter is over oiled and has your air sensor fouled up? Happened to my step dad's cai on his tick. Pop out your sonsor and hit it with some brake cleaner, see if that helps.
Old Jan 12, 2008 | 11:26 AM
billcat's Avatar
billcat
ok so the engine light came on last night, well on my way to Autozone this morning i stopped to vacuum out my truck. When i started the truck again the light did not come back on, so i just went home. Weird or no?
Old Jan 12, 2008 | 12:14 PM
jtswkd's Avatar
jtswkd
ORIGINAL: ericemery
are you talking the sensor that you put in the new intake tube?
Yes, if it gets too much oil on it from an overoiled filter, it will throw a code. My step dad's ford with a K&N did it and i had a simiar problem with a car i used to have. Just sprayed the that sensore down to clean it off, and i worked fine.
Old Jan 12, 2008 | 07:52 PM
superdak05's Avatar
superdak05
after you did the upgrades, did you reset the pcm? if not pull the neg. battery cable. then take ignition and turn it all the way and hold it there for 20 sec. this will clear the pcm. reconnect the battery cable and start and stop truck 3 times. on the third time let truck run for a while to learn the new air paramiters. this may be the cause of the problem.
Old Jan 12, 2008 | 07:59 PM
Frenchy's Avatar
Frenchy
You could do that, or do the way I like to do...
Open hood, close eyes, and start pulling fuses, and then guess where they go back....
...or not, that was a joke... btw... ;-)
Old Jan 13, 2008 | 01:46 PM
billcat's Avatar
billcat
i think i will try both ways, if the light comes back on. thanks a million
