Adding Cruise on a 6 Speed
Old Feb 4, 2008 | 01:43 PM
cramerica's Avatar
cramerica
Default Adding Cruise on a 6 Speed
Several guys here have bought the $50 cruise control switches from a dealer, and the word is it's a super easy install and works seamlessly. Has anyone done this with a manual? My only concern is that there isn't a cruise interrupt switch on the clutch.
Old Feb 4, 2008 | 04:33 PM
Frenchy's Avatar
Frenchy
Default RE: Adding Cruise on a 6 Speed
Well, I know my truck has cruise and it's a 6spd...
I'm not 100% sure on what else would be needed, but I do know it can be done! :-)
Old Feb 4, 2008 | 06:19 PM
Racinartist's Avatar
Racinartist
Same here. I have a 6spd with cruis-o-matic.
I think cramerican is on to something though. It wouldn't seem to make sense that Dodge would put an interrupt sensor on the clutch of every truck with a manny tranny. But then...Dodge has been known to do some pretty weird things.[&:]
Old Feb 5, 2008 | 02:30 AM
BrandonMiller's Avatar
BrandonMiller
doesn't really make sence that all I had to do was plug a switch in to get my cruise to work either, nor does it make sense that I bought a dodge made for my truck wiring harness for towing and it doesn't use the factory fuses, bleh..
Old Feb 5, 2008 | 09:05 AM
donkeypunch's Avatar
donkeypunch
King Jackass
Brandon,
So, do you happen to have a part number for that switch? I called my dealership asking for it, and was told that it was a whole kit...$250+ a star scan...$100. I am quite sure my dealership parts guys are not the sharpest knives in the drawer, so that may explain it.
Any thoughts?
Old Feb 5, 2008 | 09:56 AM
BrandonMiller
let me know if you can see this ok
[IMG]local://upfiles/80426/2B03C488069247CCB3101C392FFAFBBF.jpg[/IMG]
Old Feb 5, 2008 | 10:13 AM
patman0323's Avatar
patman0323
brandon, if i understand correctly all you did was add the switches and the wires were already there? and it works fine?
Old Feb 5, 2008 | 11:53 AM
BrandonMiller
10-4
Old Feb 5, 2008 | 11:58 AM
patman0323's Avatar
patman0323
huh. see now i would have thought that dodge would not have given you all the wires and all that other suff. thanks for the info im buying them parts tonight.
Old Feb 5, 2008 | 12:07 PM
cramerica's Avatar
cramerica
Frenchy -
I don't doubt that I could install the switches and have it cruise, but I'm worried that if I'm cruising and want to downshift, pushing in the clutch would redline the engine. However, the computer holds the revs for a couple seconds when the clutch is in, so maybe it knows where the pedal is...
I'm speculating because the Dodge service tech had no idea one way or the other; shocking.
I'd like to try the switches and return them if they don't work...if they use quick connects (I'm sure they do), maybe the service department would help me out with that.
