'07 Dakota lift ?????
Old Feb 9, 2008 | 05:11 PM
khowe4599's Avatar
khowe4599
Default '07 Dakota lift ?????
Is there anything I can modify in my suspension to make my truck a little highr? Like any tension bars or anything like that?
Or... what is the best way to make my truck just 2 or 3 inches higher without having to spend thousands of dollars?
Old Feb 9, 2008 | 05:19 PM
hot_asphalt's Avatar
hot_asphalt
Default RE: '07 Dakota lift ?????
i'm not 100% on this but i'm pretty sure if you go the suspension lift route that, that's where you're going to be spending thousands of dollars. go with a body lift and it's only like 200$- $500
Old Feb 9, 2008 | 05:44 PM
MonkeyWrench4000's Avatar
MonkeyWrench4000
You can get a 2" lift easy, and cheap. I have it installed, and so do many others. You buy the Trail Master 2" lift/leveling kit for the front end, the kit is 2 coil spring spacers. Then, you buy a 1" or 2" lift block kit for the rear. The front kit is $80 the rear is around $25.
I will post a pic of how my truck came out with the kit, and larger tires, 265/75-r16 in a min.
Old Feb 9, 2008 | 05:50 PM
MonkeyWrench4000
Here is my truck (red) next to a stock truck.
and here is the truck just sitting on the street with the lift and tires.
and 1 more..
Old Feb 11, 2008 | 12:26 AM
donkeypunch's Avatar
donkeypunch
King Jackass
Where did you go to get the 1" or 2" blocks?
I ordered my 2" TM kit...can't wait for the install.
Old Feb 11, 2008 | 09:35 AM
Racinartist's Avatar
Racinartist
Only if you have the 8.25" axles.[:@]
Old Feb 11, 2008 | 10:57 AM
BrandonMiller's Avatar
BrandonMiller
You can get blocks for any axle..
If you don't have a local spring shop email me the dimensions and I can ship you out something custom. Ya might try a 4x4 shop or something rather than a parts store too..
ORIGINAL: Racinartist
Old Feb 11, 2008 | 12:51 PM
MonkeyWrench4000
Yeah, I got mine at autozone, 1" aluminum blocks, with a set of u-bolts, but i have the 8.25" axle. If you have the larger axle, you can order the proper u-bolts and blocks online, every truck/suspension place has blocks and u-bolts.
Also, my blocks have no angle correction, its not needed.
Old Feb 11, 2008 | 02:57 PM
white26golf's Avatar
white26golf
what all goes into installing rear blocks? I have the RC lift with the 1 1/2" rear blocks, but I want a bit more rake to it....right now I have none, and I think after adding my top, its not exactly level anymore....was thinking about going down to autozone, and getting some 2 inch blocks and putting them on myself, but wondered if it took more than my jack and basic mechanic tools.
