Broken Headlights
Old Feb 18, 2008 | 09:50 PM
donkeypunch's Avatar
donkeypunch
King Jackass
Default Broken Headlights
I purchased a set of Silverstar bulbs for the headlights and turn signals. Upon removal of the headlamp, I un-screwed the three retaining bolts and the headlamp would not come out. Upon feeling like an idiot, I went to the owners manual. It states "remove 3 bolts, then tug to remove the headlamp from housing". Well, that metal ball that seats in the white clip didnt come out, it broke the surrounding material on the headlamp.
Has this happened to anyone?
Old Feb 18, 2008 | 10:11 PM
turbot_bird's Avatar
turbot_bird
Default RE: Broken Headlights
I pull mine when I race and never had a problem so far......
Old Feb 18, 2008 | 10:32 PM
donkeypunch
King Jackass
Do the white clips come out when you pull them? Or does the ball seperate from the clip?
Old Feb 18, 2008 | 10:47 PM
blackdak06's Avatar
blackdak06
the ball joint is supposed to seperate from the white clip, but I too broke one of the white clips the first time I removed my headlights. It doesn't seem to have much of an effect on anything, but I am going to get a new white clip eventually
Old Feb 18, 2008 | 11:02 PM
blackdak06's Avatar
blackdak06
my silverstar bulbs didn't last two long, each one was blown within 10K miles.
Old Feb 18, 2008 | 11:12 PM
donkeypunch
King Jackass
Yeah, well instead of breaking the white clip, it broke the headlight. You don't suppose the warrenty would cover this do you?
Old Feb 18, 2008 | 11:21 PM
turbot_bird
probably not
Old Feb 19, 2008 | 12:57 PM
DakSport's Avatar
DakSport
ORIGINAL: turbot_bird
This might sound like a stupid question, but, why do you pull your headlights out when you race?
Old Feb 19, 2008 | 01:38 PM
donkeypunch
King Jackass
Due to the location of the airbox, any additional cooler air (going down the track) would enter the on to/close to the air filter. This will also reduce under-hood temperatures as well.
Old Feb 19, 2008 | 01:48 PM
DakSport's Avatar
DakSport
Ah! That makes sense. Thanks donkey.
