front end really squeeeeeeeaky
Old Mar 11, 2008 | 08:31 PM
nowick's Avatar
nowick
Default front end really squeeeeeeeaky
help anyone have any idea what could make my front end squeaky its really bad just happened instantly it was fine when got home itsounds like a really bad mattress in a ***** house. it has 40,000 on it its bad on both side hell, everywhere and everythingmakes noise. I looked for grease fittings but it all seems sealed.
Old Mar 11, 2008 | 09:39 PM
Deer Hunter's Avatar
Deer Hunter
Default RE: front end really squeeeeeeeaky
Holy Crap! The same thing happened to me on thursday 3/6, except it was just the right side. I got under it and found just the slightest bit of movement in the lower ball joint, called a mechanic friend, and he said stop by monday. On friday, it rained like hell and the squeak disappeared and hasn't been back yet. My mech buddy said he was surprised I saw such slight movement in that ball joint, that currently it is not a problem, and doubted that was the cause of the squeak. Just turned 57K on truck. Beats the hell outta me. Try spraying all the rubber grommets with PB Blaster or some kind of spray lube. And check your front end components, other guys have had their ball joints replaced. Anotherquality Dodge component. Ball joints should not be going bad at such low mileage. I do 90% highway miles.
Old Mar 12, 2008 | 12:22 AM
turbot_bird's Avatar
turbot_bird
I took my grease needle and put grease in the boots covering the joints
Old Mar 12, 2008 | 07:45 AM
graythang's Avatar
graythang
Try having the control arm bushing replaced. Squeek be gone!
Old Mar 12, 2008 | 01:18 PM
niftyguy239's Avatar
niftyguy239
I too also have the squeaks in the front, but it's worse in the rear. When ever I go over a bump and the rear of my truck goes over it, it has some squeaking but it also rattles like something is loose or busted. I visually inspected the rear nothing found wrong.
Old Mar 13, 2008 | 08:59 PM
nowick's Avatar
nowick
problem solved it was aball joint just put a hole in the boot and filled with lube it worksforme. I'll see how long it lasts.
Old Mar 15, 2008 | 10:31 AM
06babyblue's Avatar
06babyblue
it's your stabilizer/sway bar links. my 06 has it in the front left, with only 17k miles.
there's a nationwide backorder on these links because they're going bad on a boatload of dakotas. lucky for me i'm still under warranty and the fix can be on Dodge's dime.
