Could I have LSD?
Old Mar 14, 2008 | 09:31 PM
Jr. Mechanic's Avatar
Jr. Mechanic
Default Could I have LSD?
Today I washed the truck, vacuumed it, and steam cleaned the inside. As I was putting it away, I "accidentally" stepped on the gas a little too much Upon looking at the tracks, there are two, perfectly even tracks in the stone. I know it may be different from the road and on stone, but it was just too perfect. I looked in the glove box and there is no sticker. It is an 06 3.7 ST club cab
Old Mar 14, 2008 | 09:48 PM
Frenchy's Avatar
Frenchy
Default RE: Could I have LSD?
YOU LIE!!!!!
You don't "ACCIDENTALLY" step on the throttle...
Your foot slips, with style...
Old Mar 14, 2008 | 09:49 PM
Jr. Mechanic
Yep, you got me.
Old Mar 14, 2008 | 10:00 PM
wink2873's Avatar
wink2873
i highly doubt they would put LSD in a base model. sometimes an open diff will spin both if they are both in a low traction situation, mine does every once and a while. if you really want to find out, jack up the back end and move one of the tires forward. if the other tire moves in the same direction you've got LSD, if not you got an open diff.
Old Mar 14, 2008 | 11:39 PM
Frenchy's Avatar
Frenchy
As to the question you are asking in this thread... does everything look funky like, multiple colors, tie-dye like, and trees and stuff, talk to you?
If so, yes, you have LSD.
Old Mar 15, 2008 | 12:27 AM
BAdassR/T's Avatar
BAdassR/T
do a burn out u will find out quick if u have it- if theres 1 tire u dont if theres 2 u were right
Old Mar 15, 2008 | 09:29 AM
superdak05's Avatar
superdak05
yea, lsd is pretty cool. i once pulled over on the side of the road so the multicolored dinasours could cross. but if you leave marks like this on the payment then you have lsd, but not likrly in a 6 cyl
[IMG]local://upfiles/31284/7C7188398A864230A147295CD38E8034.jpg[/IMG]
Old Mar 15, 2008 | 02:42 PM
rookie's Avatar
rookie
maybe the LSD made you see two wheel marks instead of one! there is a big difference between a vehicle w/ LSD and a driver w/ LSD. the operative word would be control.
Old Mar 18, 2008 | 09:46 PM
billcat's Avatar
billcat
all to funny!!!, but what is lsd on a vehicle?
Old Mar 18, 2008 | 09:47 PM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
Limited Slip Differential
