IMPORTANT!! Monroe front struts now available for 2005 Dak.
Old Jun 6, 2008 | 10:48 PM
  #41
Rayzuli's Avatar
Rayzuli
Default RE: IMPORTANT!! Monroe front struts now available for 2005 Dak.
Thank you very much for your help!!! GREAT!! I can wait no longer to have this shocks.....
I will start posting pictures of my truck and well I hope to have this socks soon.
Rayzuli
Old Jun 12, 2008 | 04:35 PM
  #43
djsilver's Avatar
djsilver
I just ordered both fronts and rears from Auto Barn. I found a valid promotional code by searching on line (SPRING08 is worth $10 off). Free shipping and the total for all 4 was $241.80. I'll do my own fronts but i'll be using 2 pairs of spring compressors. As mentioned in another thread, the front spring rateis close to 500lb/in!
Old Jun 13, 2008 | 10:11 PM
  #44
wlk404's Avatar
wlk404
Do you have the part numbers for all four shocks(and struts)?
My parts guy insists that the 71100 is for the 2005 only and says he checked with the dealer to confirm.
According to him the 2006 version will be out in July.
Thanks for your time.
Old Jun 14, 2008 | 10:08 AM
  #45
Altair's Avatar
Altair
Dak attack!
ORIGINAL: wlk404
They're both the same, if you need confirmation go to your local dealer and get the VIN# off an 05 (if yours is an 05 then get the VIN off an 06 or 07). Walk into the parts department and ask them to look up the front struts for the VIN# you got off the lot and for your VIN#, they will be the same part.
Old Jun 14, 2008 | 08:57 PM
  #46
Damn Dirty Ape's Avatar
Damn Dirty Ape
ORIGINAL: LB
05-07 are the same, infact my parts guy corss referenced my 05 Lamarie to an 07 TRX and it is the same PN#. I replaced mine last year and installed a Trailmaster leveling kit.
I am now waiting on feedback on the Monroe's with the leveling kit!
Welcome to the board, there are a bunch of great people on here!
LB
COrrect me if I'm reading the above wrong, but the TRX and laramie shocks are *not* the same part #.. For starters the TRX are red ...
Old Jun 15, 2008 | 01:31 PM
  #47
LB's Avatar
LB
You know,
Thats what I thought but I have never seen one except in brochures. We took the VIN off a brand new 07 TRX4 V8 on his lot when we did it, and the struts were black. Have you seen one with red struts?
Edit (Da, I just read your sig,I assumeyours red?)
Interesting, might have to do it again,
LB
Old Jun 15, 2008 | 06:32 PM
  #48
Damn Dirty Ape
ORIGINAL: LB
You know,
LB
yea they are red, they've replaced both for blowing out and they had to wait about 2 weeks each time as they were B/O on just the dakota shocks, then even moreso on the trx4 ones.
Old Jun 19, 2008 | 06:56 PM
  #49
hlpruner's Avatar
hlpruner
My front struts arrived from AutoBarn $159 delivered (took about 8 days from the factory).Not having the coil spring compressorsended up costing me an additional $180 for the dealerinstall. This whole ordeal reminded me just how much I hate taking anything tothe dealer for service. One dealer quoted 3 hrs labor at $330, obviously I didn't go there. The dealer I selected called to tell my that the sway-bar link broke "it was frozen due to rust",which means they put liquid wrench on it for about 10 min, then beat the hell out of it with a hammer until it broke[:@] Thiscost me another $120 for two links (parts only). Way more than I expected to spend, but I now have a1 bounce vs. 3 bounce Dak. Although Monroe only listed strutsfor an 05, as noted by ericemery& LB, they did fit my 06.
Thanks guys!
hlp
Old Jun 19, 2008 | 08:47 PM
  #50
Mahadigus's Avatar
Mahadigus
Sway bar links on dakota's and caravans are garbage and break for me all the time when I'm trying to remove them, the nuts rust on and are honestly garbage at that point. Most of the time it takes heating them up then blasting them withmy impact before they come remotely loose.....another **** design by dodge imo.
