right and left coil
Old Jun 21, 2008 | 08:12 PM
themoneyshot's Avatar
themoneyshot
Default right and left coil
i took out my coils to install the leveling kit and noticed they have different numbers. does anyone know which is left and which is right? by the way what would happen if i switched the two?
i took the struts to a local garage with a wall mounted strut compressor and he stated that he was scared the coil was going to shoot out if he tried to compress it. long and short he refused to do it and worse refuesd to let me take the risk. did anyone have trouble without a hydraulic compressor?
i bought the monroe 71110 because i chewed up one of the struts threads. there is a big difference just in hte hand. the stock i can fairly easily compress and it shoots right out. the monroe take alot of effort and slowly return. hopefully one day the will be installed and i can tell you how they are on hte truck.
Old Jun 21, 2008 | 09:46 PM
MonkeyWrench4000's Avatar
MonkeyWrench4000
Default RE: right and left coil
What kind of panzy shop did you go to where they refused to compress the coil springs because they were afraid? Isnt that there job?
Go to a shop that will actually do it. I have never run into that problem in my life lol. Good Luck.
Old Jun 22, 2008 | 07:54 AM
themoneyshot
thats what i thought.i said let me do it. and he was like "NO!! it is too dangerous!!" i told him i had steel toe boots on but no luck.
Old Jun 23, 2008 | 06:35 AM
sdsdsd's Avatar
sdsdsd
I had mine changed at the Dealer and the tech stated it was scary, very hard to compress.
Old Jun 23, 2008 | 05:38 PM
Altair's Avatar
Altair
Dak attack!
ORIGINAL: sdsdsd
I did it partially with normal strut compressors from Napa, that's far scarier than a wall-mount, couldn't compress them enough either. The shop with the wall mount did it in all of 20 seconds and the tech looked like he could have done it in his sleep.
Old Jun 23, 2008 | 06:36 PM
Parts/Service's Avatar
Parts/Service
If you are talking about the factory part numbers, if the part number ends in an odd number, it is for the left side, an even number is for the right...
Old Jun 29, 2008 | 03:43 PM
WvChamp's Avatar
WvChamp
Very nice looking Truck James
