where to put it?
Old Jun 28, 2008 | 03:53 PM
NJJer's Avatar
NJJer
Default RE: where to put it?
ORIGINAL: ericemery
So being a tech, you know that sludge is carbon right?
also, how long does it take sludge to develope? 2k miles? maybe?
Part of sludge is carbon, correct. Not all of it.
How long to develop? All depends on the condition of the engine. EDIT: It should not develop at all.
I do 3-5k oil changes on most of my vehicles. All monitured with by Blackstone Labs. You can pull the pan on my "beater" car (100K on it) and find ZERO sludge in the bottom. I know this as I just did a pan gasket on it.
If someone is devolping sludge, we have to look at why? Improper maint? Poor oil? Short trips? Etc.
If sludge develops in 2K, then there is a serious problem.
EDIT: I don't want this to turn into a pissing match. I have seen that happend before, and that is not my intention.
Old Jun 28, 2008 | 04:19 PM
NJJer's Avatar
NJJer
Lets try and keep this simple so maybe others can follow along.
What is it that you think you find in your filter?
Questions for you,
Your trips, how long are they?
Do you ever do any short trips? 10 miles or less?
What I think you are finding in your filter is infact the Seafoam and any "dirt" it may have picked up. The oil is what normaly "grabs" the dirt, but the Seafaom may also be grabbing it and holding it until the filter gets it.
It is not good that you find sludge, I just hope ot is not in an isolated area of the filter and whatever it is, is spread thru-out the filter element evenly. You would not want you filter to clog. I may be way off base with what I just said, as I do not know the amount of "sludge" you are finding.
Best way to avoid it, use a good oil and filter, change it when needed. You choice on when, but at the very least, follow owners manual.
Get engine up to full operating temps.
Keep it tuned up.
Sludge, it comes from problems. A few are:
Ring wear
Valve guide/seal wear
Oil getting into the breather system.
Old Mar 13, 2009 | 07:58 PM
FirstDodge05's Avatar
FirstDodge05
Don't mean to bring this thread back from the dead, I was gonna start a new thread but found this one-- I don't think the answer to the OP's question was ever answered. At just over 50k miles, I'm looking to possibly run some Seafoam through my truck, but as the OP asked, where is the brake booster line? If possible, can someone post a pic of which one to remove?
Old Mar 14, 2009 | 10:04 AM
Racinartist's Avatar
Racinartist
Originally Posted by NJJer
monkey see, monkey do.
Signed, ASE Master Tech and Profesional Race Engine Builder
What kind of racing engines do you build?
Hopefully you're better at that than spelling. Haha, just bustin'.
