Club Cab Read headrest Removal w/ Pics
Old 08-19-2008, 10:13 PM
wyattc329's Avatar
wyattc329
wyattc329 is offline
Default Club Cab Read headrest Removal w/ Pics
Tools Needed:
8mm or 5/16 socket
Estimated time:
25-30 mins
First I just want to say this was WAY easier than I expected it to be.
Ok first, if you haven't already done so, you need to remove the jumpseats, mine were already out, so if you don't know how to remove them, ask. That's even easier.
Next you need to remove the "C" panel trim. That's the trim with the seatbelt attached to it. Now you have two options you can
A. Remove the upper trim and the seatbelt,
B. Bend the lower trim plastic out from the upper trim and pull it out of the way.
I opted with B and just removed the lower trim leaving the upper in place.
Once this is completed on both sides next comes removing the back panel. There are no screws or anything attached to it, it's simply located the clips and give it a good tug.
This leaves the head rest bolts exposed. There are two per side.
Once you remove the second bolt hold on to the headrest because it will fall straight out of the ceiling. Accomplish this on both sides and you are done.
Well except for putting the truck back together, but it's all snaps just put the back wall on first and your home free.
Before:
After:
Any questions ask.
Old 08-19-2008, 10:21 PM
lghtngblt02's Avatar
lghtngblt02
lghtngblt02 is offline
The RAM Administrator
Dodge Forum Administrator
Good work man!
Old 08-19-2008, 10:24 PM
SilverGhost1's Avatar
SilverGhost1
SilverGhost1 is offline
nice job!
Old 08-19-2008, 11:03 PM
baracis's Avatar
baracis
baracis is offline
Awesome, thanks man! If I didn't have PT in the morning I'd go out and do that right now.
Old 08-20-2008, 06:05 AM
blkmagic's Avatar
blkmagic
blkmagic is offline
Nice clean look. I first looked at my truck, I thought they were a built in rifle rack or something...This is on my "Gotta DO" list...
Old 08-20-2008, 09:22 AM
superdak05's Avatar
superdak05
superdak05 is offline
it does make the truck look alot cleaner.
Old 08-20-2008, 01:06 PM
importkiller76's Avatar
importkiller76
importkiller76 is offline
I never realized that the headrests in a CC were so frigginn huge! My qc ones are not nearly that fugly....and definatly not attached to the roof!
Old 08-20-2008, 01:29 PM
baracis's Avatar
baracis
baracis is offline
Whew! Got mine out. I shortened it up a bit tho. I didn't completely take anything off. Pulled loose what I need to, then did the same with the back. Stuck a ratchet back there and wham, bam, thank you ma'am. Looks MUCH MUCH better now. This forum is full of all kinds of awesome ideas.
Old 08-20-2008, 01:32 PM
wyattc329's Avatar
wyattc329
Yea I only took it off to show you what you were dealing with.
Quick Reply: Club Cab Read headrest Removal w/ Pics
