Engine Tick
Old Aug 20, 2008 | 08:02 AM
boopadoopa's Avatar
boopadoopa
Question Engine Tick
Ok, So I have this Engine tick when the truck is cold and I think its comming from the Exhaust manifold Passanger side. How much crap do I have to remove to get to the bolts
to see if ones loose or snapped off? The air box, Heat shields etc? Is this a hard job to fix if one is snapped off? Im hoping its comming from the manifold and not a lifter. Any suggestions? Its a 05 Quad cab 51000 miles
Old Aug 20, 2008 | 10:42 AM
Elvis Is Blacked Out's Avatar
Junior Member
I think I have that lifter tick. What do we do about it? Is there a fix or do we leave it alone?
Old Aug 20, 2008 | 12:07 PM
boopadoopa's Avatar
boopadoopa
It is pretty loud when startup but mine goes away when the engine gets warm..
Ive listened at different places and mine seems to be on the passenger side but im not sure if its a lifter or exhaust? Im going to look at exhaust firse as it might be the easiest
Old Aug 20, 2008 | 04:05 PM
BAdassR/T's Avatar
BAdassR/T
i would check exhaust then move on to lifters- do the simple stuff first-
Old Aug 20, 2008 | 04:11 PM
baracis's Avatar
baracis
Yea, thought I had a tick as well. Went to the dealer and I had a small exhaust leak, whew! Got me some new cats tho!
Old Aug 20, 2008 | 05:22 PM
Jadman's Avatar
Jadman
Default Same thing!
I also have a passenger side leak in the Manifold. Midas said they have done a few on our trucks. He couldn't give me a quote because "It is a pain in the *** to drill and tap the bolts." Can't wait to get it fixed though, annoying! Has anybody else had theirs repaired? If so How much was it? Thanks.
Old Aug 20, 2008 | 11:04 PM
mprohr's Avatar
mprohr
Mine does it to. Only for a few minuets in the morning while cold. It really kind of sound like a spun bearing rod knock to me....pretty low in the engine....probably more on the drivers side. It has been described as sounding like a diesel by many people in many forums. 2 guys actually had rod knock diagnosed as the problem and had bearing replacement completed. If this sound like what you have...and it has been diagnosed and fixed by replacing broken exhaust manifold bolts...please speak up, and make a whold bunch of us feel better. Baracis, can you be more specific than "tick"? Thank you. I would really like to get to the bottom of this.
Old Aug 20, 2008 | 11:06 PM
mprohr's Avatar
mprohr
I forgot to mention it only has 39,000 miles, and I have documented dealer evidence of very regular oil changes.
Old Aug 20, 2008 | 11:09 PM
baracis's Avatar
baracis
Not really. Just sounded like tick. haha
