Oil change message
Old Aug 27, 2008 | 04:36 PM
ptvegas's Avatar
ptvegas
Default Oil change message
I have a 08 quad cab sport. 4.7. I have changed my oil at a regular mechanic shop, but the "Change Oil" message keeps coming on where the mileage shows until a few seconds then goes off. Does anyone know how to shut that off without going to a dealer?
Thanks
Old Aug 27, 2008 | 05:01 PM
baracis's Avatar
baracis
Not sure if Autozone could do that for you with their programmers. Might be worth a shot. If not they could probably point you in the right direction.
Old Aug 27, 2008 | 05:43 PM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
I dont think Autozone can do it, they just have readers/scanners, not programmers but check your owners manual, I am sure theres some screwy sequence like turn the key 3 times, scratch your ***...err head for 10 secs, and then hit the the light switch
Old Aug 27, 2008 | 06:53 PM
VA Dakota's Avatar
VA Dakota
Doesn't anyone read their owner's manual....LOL
Page 162 for 2008 Dodge Dakota
Change Oil Message.....
Your vehicle is equipped with an engine oil change
indicator system. The “Change Oil” message will flash in
the instrument cluster odometer for approximately 12
seconds after a single chime has sounded to indicate the
next scheduled oil change interval. The engine oil change
indicator system is duty cycle based, which means the
engine oil change interval may fluctuate dependent upon
your personal driving style.
Unless reset, this message will continue to display each
time you turn the ignition switch to the ON/RUN
position. To turn off the message temporarily, press and
release the Trip Odometer button on the instrument
cluster. To reset the oil change indicator system (after
performing the scheduled maintenance) refer to the following procedure.
1. Turn the ignition switch to the ON position (Do not start the engine).
2. Fully depress the accelerator pedal slowly three times within 10 seconds.
3. Turn the ignition switch to the OFF/LOCK position.
NOTE: If the indicator message illuminates when you
start the vehicle, the oil change indicator system did not
reset. If necessary repeat this procedure.
Old Aug 27, 2008 | 07:04 PM
baracis's Avatar
baracis
Or just do that.
Old Aug 27, 2008 | 09:40 PM
superdak05's Avatar
superdak05
the same way i used to get the stupid numbers to stop blinking on my vcr, put a piece of electrical tape over it
Old Aug 27, 2008 | 10:11 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
lol @ superdak thats hilarous
Old Aug 27, 2008 | 10:48 PM
lghtngblt02
haha nice one super..
See I told ya it was a screwy sequence
Old Aug 29, 2008 | 12:10 AM
ptvegas's Avatar
ptvegas
Default Change Oil Message...
Owners Manual??? what't that?
Just Kidding..
Thanks VA,,, I had to do a similar gyration to get the seat belt ringer to turn off, but thanks.
